will this amp work????
Discussion in 'Car Stereo Amplifiers' started by bluntmanchronic, Sep 25, 2009.
  1. bluntmanchronic
    bluntmanchronic Full Member
    here is the sub specs.
    DUAL 1 | DUAL 2
    Fs: 35.6 Hz | 34.6 Hz
    Re: 0.7 Ohms/coil | 1.4 Ohms/coil
    Qms: 5.72 | 5.90
    Qes: .24 | .22
    Qts: .23 | .22
    Mms: 256g | 272g
    Sd: 810cm^2 | 810cm^2
    Vas: 71.6 l | 71.6 l
    Spl: 93.2dB 1W/1m | 93.1dB 1W/1m
    Bl: 18.3 N/A | 27.2 N/A
    Xmax: 28mm * | 28mm *
    Rms: 2000W * | 2000W *
    Sealed box: N/A cuft | N/A cuft
    Ported box: 3-5cuft | 3-5cuft
    Sub OD: 15.625” | 15.625”
    Cut ID: 14.125” | 14.125”
    Mounting depth: 8.750” | 8.750”
    Displacement: 0.21cuft | 0.21cuft
    here is my question, if i have 2 of these subs if i get 2 of these amps will it work to power my subs?
    http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20695
  2. cccullen
    it sure will... Pricey amps....
  3. bluntmanchronic
    ok good, well its the only one that i have found that has enough power and will work.
  4. Kvo_8
    Kvo_8 Full Member
  5. bluntmanchronic
    those are good tooo.
    but ive been looking around for a while and i cam across these,
    Crunch GP3000DPRO 1-Channel D Amplifier
    i hear really good things about them, what do you think about them?
  6. cccullen
    Crunch is a step lower then Hifonics. Made by the same company, it doesn't put out rated power.
  7. bluntmanchronic
    oh well i have heard that they can give more power thant hey say..
    but im not sure. im honestly just want 2 3k watt amps that can do 3k watt rms, not a 3k watt amp that only does like 1800 watt rms like on mny amps i keep finding....
    i need some mega halp on finding an amp, its the only thing im having trouble wiht at all...
  8. pedro quiroga
    ive seen 5 0f those on 5 18's and wow!!! but my bud also had a 1/2 ton of batts too. just remember to back up the power going to them.
  9. pedro quiroga
    not too sure on those amps. im sure it will put out over 1k but not sure if it will do its rated power.
    have you looked into power acoustic amps. they work well and i have seen a lot of those in comps..lots!
  10. pedro quiroga
    yeah i know some guys with a few of those. they work well for the money.
  11. bluntmanchronic
    ok so i can use those? cool...
    now what does it mean by not bridgeable?
  12. pedro quiroga
    its a mono amp. so its already just 1 channel.
  13. bluntmanchronic
    alright cool thanks for your help again...
  14. pedro quiroga
    no prob, im here to lend a helping hand.
  15. bluntmanchronic
    ha and you've done one hell of a job helping me, i was clueless when i started out, but now i know a few things thanks to you and ccullen.
  16. jonnyv713
  17. bluntmanchronic
  18. jonnyv713
    yup. that'll work
