will this amp blow my 2 Kicker comp 12s?
Discussion in 'General Car Audio Discussions' started by zak97gt, Jan 3, 2011.
  1. zak97gt
    zak97gt New Member
    I have this amp: http://www.caraudiodeals.com/lanzar-maxp1200-p-4091.html and I want to wire it 2 ohm to my 2 c12s. This should put out about 450 to each sub which is a little above recommended peak (300w). Do you think that Kicker rates these subs low to play it safe, and I could run this without blowing em up?
  2. 6.5ldiesel
    6.5ldiesel Full Member
    That amp will not make 450w RMS per channel...
    If it is put into clipping, then yes it CAN cook your subwoofers. It will not if you set your gains right
  3. zak97gt
    zak97gt New Member
    It says on the page 900RMS at 2 ohms? and thats what my box is wired to. so that would be 450 per sub, no?
  4. pedro quiroga
    the lanzar brand tends to embellish their ratings. thats why it won't do 900 @ 2 ohms. not out of a 68 dollar amp anyways.
    what is the maximum you are willing to spend on an amp and the wiring involved?
  5. eviling
    eviling Full Member
    i woudlnt touch that amp with a 100' stick...60 for 1800 wats rms is bs. that has to be the dirtiest power you could even imagine.
