Will these fit?
Discussion in 'Car Stereo Speakers' started by jlfox, Apr 15, 2007.
  1. jlfox
    jlfox Full Member
    What's up, this is my first post. i think yall got a great forum and its helped me a lot in some of my decisions :D
    Anyway..
    Im looking to purchase two 6.5" Polk Audio MMC6500 component speakers in the front for my 4runner. And 5.25" Polk Audio db5250 component speakers for the rear. However, it says i need 6.75 speakers for the front. And they dont make the MMC6500 in 6.75".
    This is actually a three-part question:
    Would the 6.5" still fit my fronts?
    And if they do...are these speakers good speakers for my needs? i listen to mostly rap and rock. and im running two 12" W3v3's in a sealed box.
    And if the are good...lol...then what 4-channel amp for a pretty decent price should i be using.
    Thanks!
    zach
  2. CadillacETC1997
    you MAY need to build a plate
    but shouldnt be too bad
  3. jlfox
    jlfox Full Member
    do you or anyone else know of any good 6.75" speakers that would compare to the Polk's. It'd probably be easiest to get the size required. ha. juuust in case
    and also a good 4-channel amp for all this
  4. TheViking
    Polk Audio makes Exceptional speakers in my opinon....making plates/adaptors is not too hard.....
  5. jlfox
    jlfox Full Member
    really, so if i was to make a plate. what would i do to make one.
  6. aznboi3644
    custom baffles would make the speaker sound better also....if installed correctly
  7. TheViking
    Just get some 1/4 inch masonite, then trace out your factory speaker onto it...
    then center up your new speaker onto it, then trace it out....cut it all out...there ya go!!
  8. DaveDSMer
    DaveDSMer Full Member
    plus masonite is cheap, i got a huge sheet of 3/8" masonite at home depot for like 15 bucks, enough to do about 25 baffles.
  9. pedro quiroga
    my polk 6.5 coaxials came with an adaptor for a larger door opening.did your's.or do you not have them yet?
  10. jlfox
    jlfox Full Member
    no i haven't gotten them yet, i need to get another hundred bucks. darn car payments :mad:
