I recently bought an old corvette, decided to leave the dashboard unmolested and go with a stand alone system in the rear compartment, and throw in some extra speakers up front. I'll try to over-explain, hopefully someone can figure out what I'm doing wrong. I had my uncle install the stand alone section (Wiring the amp to the battery, remote lead in to the CD player ect..) and figured I'd be able to handle the two front speakers. Guess I was wrong! So the 6X9's, amp, and CD player all work fine, just can't get the fronts to work. Here is the rear stand-alone section. 2 6X9's, 4 channel amp, and a Sony CD Player. By chucas11 at 2011-06-08 Here are the 6 1/2's I installed in the kicker panels. By chucas11 at 2011-06-08 Wiring on the back of the 6 1/2's By chucas11 at 2011-06-08 By chucas11 at 2011-06-08 Wiring to the amp (12 gauge wire, the top are the front speakers, the bottom are the rear) By chucas11 at 2011-06-08 Left and right audio cable at amp. By chucas11 at 2011-06-08 Connected to CD player By chucas11 at 2011-06-08 So my that was the visual of my though process, wire the speakers (+ to +, - to -), connect the L and R audio wire, turn it on and shazam it would work. But no Did I miss something here? What the hell am I doing wrong?? Any help would be greatly appreciated. -Luca
The amp should have a switch to turn the fader on & off. If the fader is not turned on it will not send power to all the speakers. Did you double check to make sure you have the RCA cables R-R and L-L?
