Which was should my subs go?!
Discussion in 'Car Subwoofers' started by Eclipsed, Jul 12, 2006.
  1. Eclipsed
    Eclipsed Full Member
  2. aznboi3644
    Um...the sh*t has ended so it doesn't work...What box is this??
  3. Eclipsed
    Bandpass Sub Box Features:
    Brand New !!!
    Fits Two 12" Subwoofers.
    Bandpass box ... for deep bass.
    Plexiglass on top and half of front side so you can see your subs bumping !!!
    Four Aluminum Chrome Ports.
    Custom Designed & Built with MDF Wood.
    High density Black Carpeting, all around.
    Best Quality Enclosure.
    More, Deeper Bass than conventional boxes.
    Includes Push-in Terminals on each side to hook up the subwoofers.
    Dimensions: 30" Wide x 15" Deep x 15" High
    Built with 3/4 MDF Wood.
    Box is completely sealed and is air-tight from all corners.
  4. Hautewheeler
    Hautewheeler Full Member
    link still works fine for me..
    dude, don't worry about hiding wires. Anyone who does car audio will accept that speaks are USUALLY connected to wires. Just cut them to the proper length, and install them neatly, and you won't have any problems. And please do not turn those subs around, by doing that, you completely change the design and efficiency of the enclosure, and it will sound like a cat puking a pound of rusty license plates. Mount them the way that they are shown, and your subs will last longer, too..
  5. Eclipsed
    So just run the wires under the sub edges before I screw it on tight?
  6. ramos
    ramos Full Member
    I'm not going to be mean. And rant about my extreme dislike of prefab enclosures, particularly bandpass like this one :) Going on looks alone, the subs are inverted cause there is not enough room in the smaller ported section to mount them normally. And if you did, you would make the smaller section smaller, and larger larger by moving the basket displacement. Thus changing the tuning ( not gonna be that accurate as it is ) . As for hiding the wires, no way possible to hide wires connected to inverted subs that I know of. I would try to run the wires neatly with some zip ties, or maybe some wire loom in the enclosure to dress it up. :)
  7. ramos
    ramos Full Member
    Wouldn't do that, you won't be able to get a good seal. And might end up with some cancellation. Also wiring like that would be pushing the ghetto factor to serious overload as well :)
  8. Hautewheeler
    and I'd hate to see a screw go across both wires, you DONT wanna find out how stable your amp is at 0ohms:cool:
  9. ramos
    ramos Full Member
    Judging by the choice of amp he might get the chance to find that out with out even trying :)
  10. Hautewheeler
    good one, ramos..
