Which speaker amp/spks reuired
Discussion in 'Car Stereo Amplifiers' started by vicky_gill, Jul 19, 2009.
  1. vicky_gill
    vicky_gill New Member
    I am new in car audio ...
    i hv the following
    1. head unit : POINEER DEH 5000UB WITH SUB ,USB ,IPOD
    2.JL Audio subs (two)125WATT RMS
    3.Wiring kit 280 watt rms
    4.Sub amp MTX RT4340 4 channels 560 watt
    for spec: click on this link
    www.mtx.com/caraudio/archive/rt4340.cfm
    5. front speakers 30 watt rms
    6. honda factory rear spks
    7. Honda civic si 98 coupe
    QUES: WHICH SPEAKER AND SPEAKER AMP I NEED? ...WHAT OTHER ACESSORIES I NEED? e.g any switch to turn on /off amp while stat my car?
  2. cccullen
    welcome to CAT vicky...
    What kind of speakers do you have up front? it just said 30 watts RMS. can you give us a bit more detail?
    you will not need any sort of switch to turn your amp on and off. there is what is called a REM or remote wire from your head unit with connects to your REM in your amp. That will turn the amp on when your stereo is on.
    Are you just planning to use the amp for your subs?
