Which Of These Subs Is Better??????
Discussion in 'Car Subwoofers' started by dabigpapa, Sep 24, 2006.
  1. dabigpapa
    dabigpapa Full Member
    Which of these 4 subs is the best SQL SubWoofer I plan to get 2 of them for my 2004 SS Impala PlZ Advise. Thanks. If there is better ones PlZ tell.
    1) kicker soloX
    2) JL 13w7
    3) Pioneer TS-W8102SPL
    4) Rockford T215D4
  2. TheViking
    Have you persaonally listened to all them? Cause what I tell you I think is the best will be someones elses bastard child. ANY speaker can be a good one if put in the right enclosure, yes, even a 8 inch 29 dollar radio shack special......BOX BOX BOX!!!!! that is the key!!!!!!!!!
  3. aznboi3644
    Also...please refrain from using "SQL"
    You can't have 150+ db AND sound quality
    And as Viking said...its a lot about the box
  4. pedro quiroga
    how about a set of image dynamics.i remember reading about them alot in the stereo mags back in the day.
  5. bigbassboi
    bigbassboi Full Member
    Have run a single solo x 12, soundedlike as, god loud.... I have my 8102 on order, waiting for either 2 200001 rf or two pca2000d
  6. DaveDSMer
    DaveDSMer Full Member
    out of those speakers I would go with JL
  7. ibanezFreak87
    ibanezFreak87 Full Member
    The pioneer and JL would be two of the greatest subs. The JL has more sound quality and less SQL than the pioneer. so the pioneer sub would be louder, but sound less clear.
    If your going for a good system, then buy the JLw7, but if you just want db levels. then go with the pioneer.
    I have a 12w7 run by a 500/1 and it is louder than my friends two solo x t's running 4200 watts. so kicker is overrated I think and most people will agree. RF sucks balls.
    AND... i've done work on impala's --- and the trunk space ain't crazy big. I mean, i just don't think you could fit two 13w7's or two of the SPL's . not witht the right air space that is.
  8. aznboi3644
    Dude this thread is dead....I'm pretty sure the OP left and never came back lol
  9. ibanezFreak87
    haha didn't even look at the date
  10. jmenace_thakidd
    jmenace_thakidd Full Member
    help needed
    is this spl AMP any good?
    spl audio dk2600d
    Hi Speed Digital Circuitry
    Fully Regulated PWM Power Supply
    Four Way Protection Circuit
    1 Ohm Stable
    Bridging Synchronization
    Variable Low Pass 50Hz-150Hz
    Variable Subwoofer EQ @ 45Hz
    Variable Subsonic Filter 15Hz-40Hz
    Phase Switch 0-180
    Remote Dash Mount Low Level Gain Control With Cable
    Frequency Response: 15Hz-150kHz
    S/N Ratio: 100dB
    THD: 0.5%
    System Distress Indicator
    Inputs Sensitivity: 200mv-8V
    Dual Mono Speaker Output Connectors
    Gold Plated Heavy Duty Power & Speaker Terminals
    Specifications:
    1 ch
    4ohm RMS: 1100
    2ohm RMS: 1600
    1ohm RMS: 2000
    Max: 2600
    Dimension: 15x2.7x11 (W"xH"xD")
  11. aznboi3644
    SPL isn't the greatest...but it will work.
    Overrated...doubt it can run full tilt at 1 ohm
