Which Amp?
Discussion in 'Car Stereo Amplifiers' started by crowdie, Nov 23, 2011.
  1. crowdie
    crowdie New Member
    I've recently installed 2 Ripspeed 6 X 9's in my car, specs as follow:
    Max Power: 120
    RMS Power: 60
    Speaker size: 6 x 9 (15cm x 23cm)
    Type: 3 Way
    Frequency Response: 40 - 22,000Hz
    Sensitivity: 1w/m 90db, 2.83v/m 96db
    Impedance: 4 Ohms
    I'm looking to amplify them as they are very underpowered from my current head unit set up. I'm looking at two amps within my price range (I wouldn't really want to spend more than £50)
    The first is a FLI FL450s, 2 channel, 450W max, 2 X 100w RMS at 4 Ohms.
    The second is a Mutant MT1202:
    Number of channels: 2 Channel
    Frequency Response: 20-20000Hz
    Bass Boost: 0-+18dB
    High Pass Filter / Crossover: 40-Hz-600Hz
    Load Impedance capability: 2 Ohm
    Low Pass Filter / Crossover: 40-Hz-600Hz
    Max Power: 2x95w
    RMS Power: 2x60w
    Which would you guys recommend out of the two? Or should I be looking at a different amp all together?
    Any help much appreciated!
  2. lachie113
    lachie113 New Member
    I have a kicker zx350.4 for my 6x9 and 6" splits abd they crank , can't go wrong with a kicker amp
  3. dmanvt
    dmanvt New Member
    Agreed ^ Kicker are good as for amps and things, i had the same zx350.4 cranked hard, amazing amp, just needed a bigger one for my 2 subs :) amazing amp amazing build lovin' livin loud with kicker
  4. crowdie
    crowdie New Member
    I'm Looking into the Mutant one,
    It has 2 X 60 W RMS which is exactly the same as the speakers, where as it only puts out 2 X 95w of power. The speakers are 2 X 120, will this be a problem?
