Which amp to choose from....
Discussion in 'Car Stereo Amplifiers' started by shanecbx3, Apr 20, 2006.
  1. shanecbx3
    shanecbx3 Full Member
    Well since my old amp randomly burned out...i now get to buy a new...better one. So i was looking at these two amps and i was wonder if anyone could point me in the right direction....
    Pyle PLA-2680
    2400-Watt
    2-Channel Bridgeable MOSFET Amplifier
    Output Power:
    2 x 200W RMS (15Hz to 30kHz) @ 4Ohm 0.04% THD
    2 x 290W RMS (15Hz to 30kHz) @ 2Ohm 0.04% THD
    Signal to Noise Ratio (SNR): 95dB
    Filtering:
    80Hz to 2.5kHz - High Pass Filter
    35Hz to 400Hz - Low Pass Filter
    Or
    Power Acoustik TS1920 -2 Plasma Sphere Series
    1920W
    2-Channel Amplifier
    Output Power: (10Hz to 30Hz) 0.02% THD
    (SNR): 98dB
    Filtering:
  2. Hautewheeler
    Hautewheeler Full Member
    My opinion personally, I stay away from pyle's.. I have seen too many burned out. It's just not sturdy equipment. I don't know about the new power acoustics, but I will tell you that I had several coustic's back in the day, and I thought that they couldn't be beat for the money and the amount of torture they would endure. But, like I said - new stuff, it's a gamble
    what was your old amp, and why did it burn out?
  3. jus.hurtz
    jus.hurtz New Member
    what to look for
    when looking for an amp look for a reputable brand
    as i always say "you only know better when your exposed to something grater
    so one of the most important things to look for is an amp with a good crossover section and a low THD
    some of the amps that i worked with and did very well : corssfire, interfire,mtx and there are lots more out there you just have to try them.
    i used a power acoustic amp about to months ago and it failed the test "badly"
