Whats a good HU for around $150.00?
Discussion in 'Car Audio Head Units' started by benjammin5150, Jul 28, 2009.
  1. benjammin5150
    benjammin5150 Full Member
    I dont know much about car audio, but Im looking to spend about 150 on a HU. Any educated opinions on whats good for that price?
  2. Justin220
    Justin220 Full Member
    Dear Ben, do you need a one DIN or 2 DIN head unit? Please check your height, 50mm is for single din, 100mm is for 2 din. Then to tell you the truth, it's possible to get a good single HU easily even under 150, but for double din, seems impossible...
  3. Lazy Eye
    Lazy Eye Full Member
    Also, are there any features that your wanting?
  4. benjammin5150
    its a single din. the only thing that I really need is for it to have front, rear, and sub preouts...I have a 5 channel 1000w amp, kenwood 6x9 rear, infinity 6.5 fronts...no sub yet but looking.I just want as good of sound as i can get.
  5. cccullen
    There are a lot out there for your needs. look at pioneer premier head units or Alpine.. Would you also want a head unit with T/A (time alignment) settings?
  6. benjammin5150
    What exactly is time alignment settings?...Also, What kind of sub should I be looking for with the wattage that my amp is pushing, I was thinking 10"
  7. cccullen
    well, time alignment is setting the timing from different speakers. it's more for SQ heads.
    go for a simple stereo that has 4 or 5v preouts..
    what is the exact model of your 5 channel amp? I may have asked this before, i forgot so refresh my memory if i already asked you that.
    as far as the size of the sub, it's all up to you and what your goal is for having a sub? what kind of music do you listen to? do you want crazy bass or just a little boom in the back? if you want stronger bass i would say go with a bigger sub like a 12" or higher depending on what your amp puts out
