whats a good amp for me
Discussion in 'Car Stereo Amplifiers' started by traimbault, Feb 29, 2012.
  1. traimbault
    traimbault New Member
    First! im new to this forum thing so if this is in the wrong spot im sorry
    second any help at all will be appreciated and thank you for everything in advance
    so now.. i need help choosing an amp i have 2 12in l7s and they are 750watt rms each and they are dual voice coil with 2ohm i havent the slightest clue about what brand is good and reliable or model amp to get now im not someone who can afford a fancy expensive amp so maybe if you can give me a few options at different price ranges or even brands you think are good.
    once again ANY help will be greatly appreciated thank you all!
  2. kostyam69
    kostyam69 Full Member
    those are very power hungry speakers, and you are lucky that you got the right ones if using both you'll run them at 2ohm, you'll need an amp that does about 1500RMS at 2ohm, kicker zx1500.1 is actually the amp that kicker designed to run that set of speakers, but your options are: http://www.sonicelectronix.com/item_23549_Hifonics-Brutus-BRZ2100.1D.html , http://www.planetaudiousa.com/main/591 , http://www.sonicelectronix.com/item_23550_Hifonics-Brutus-BRZ2400.1D.html , just to mention a few affordable ones... hope that helped
