What to push my new jl w3v3's
Discussion in 'Car Stereo Amplifiers' started by _Hammer, Aug 25, 2008.
  1. _Hammer
    _Hammer Full Member
    I have been running two pioneer 12's with a lanzar vibrant series 800 2 chan. Well my buddy is selling his truck and doesn't want his JL w3v3's in his ws6 so he sold them both to me for $150. Only problem the are the W3V38's aka 8 ohm. He ran a JL 500/1, I hooked them up to my Lanzar and bridged and split but them don't sound very good need advice on an AMP.
    Setup:
    2000 Toyota Tacoma
    Stock Head
    Some kind of rear speaker to av conversion
    JL W3V38 x2
    Lanzar Vibrant 800x2
    so you need an amp with more power into a 4 ohm mono load right?
    what does your amp do into a 4 ohm load in mono?
  3. pedro quiroga
    one more question. how are the subs wired?
  4. _Hammer
    _Hammer Full Member
    I really dont know jack yet about setting up systems
    what do you mean wired, 8guage to amp, briged then split 12 gauge to JL's
  5. pedro quiroga
    http://www.bcae1.com/spkrmlti.htm
    read this then you will have a better understanding of your system.
    what are the specs on the amp?
  6. _Hammer
    _Hammer Full Member
    # 2 x 200W RMS at 4 OHMS 2 x 400W MAX at 4 OHMS
    # 1 x 800W MAX at 4 OHMS Bridged 2 x 300W at 2 OHMS RMS
    # Electronic Crossover Network
    # Bass Boost Circuit
    # 2 Ohms Stereo Stable
    # Anti-Thump Turn-On
    # Illuminated Top Panel
    # Soft Turn On/Off
    # High & Low Level Inputs
    # Power & Protection LED Indicators
    # Advanced Protection Circuitry
    # Remote Control Bass Booster
    # T.H.D.: <0.04%
    # S/N Ratio: >90dB
    # Channel Separation: >65dB
    # Freq. Response: 15Hz~35kHz
  7. pedro quiroga
    well it looks like it can do at least 600 watts into a 4 ohm mono load.
    that should be close to the 500/1's power output. so maybe your subs are not wired correctly.
  8. _Hammer
    _Hammer Full Member
    Okay I have let my truck sit on a battery charger over night and when I got up it sounded great I think my battery is going bad and I think my box is way too small.
  9. pedro quiroga
    well then have your batt tested and see for sure if its bad.
    how big is the box? if it sounded great why do you think the box is too small?
  10. _Hammer
    _Hammer Full Member
    I kinda exaggerated alot, I thought it sounded good, and it did for about 10min of driving. Then they like lost power and when I turn them down they make a buzzing noise. oh ya the other day I left my amp on for about 5 hours and when I got out to my truck the subs were hittin in a series like dot dot dot I didnt even have the key in it
  11. cccullen
    sounds like wiring problems to me. check your ground.
  12. pedro quiroga
    ooo a buzzing noise? thats not good. my old kicker sub started that.
    it still played and pounded hard but at low vol had that buzzing sound.
    someone told me on of the coils is going bad(unwinding?) but will still work for a while.
  13. _Hammer
    _Hammer Full Member
    Ya I talked to the kid I bought them from and he said that he thinks I cracked my box and it is a slite blow by, my box is kinda thin like 1/4 or 5/8. are JL's rebuildable
