What should sub be set too???
Discussion in 'Car Audio Head Units' started by 7duster3, Jan 28, 2008.
  1. 7duster3
    7duster3 Full Member
    ive got a pioneer deh 9800, should my Sub setting in the audio tab be set to mono or stereo? I figured out the problem with my bass, it was too small of a box with not enough air. so now i need to set my headunit.
    Can anyone tell me some of the major settings that i should have on or off or how much of to have decent sound??
    Thanks you so much...
    7d3
    just keep fiddling with it until it sonds good to you
  3. slamitson
    slamitson Full Member
    i have the same head unit, the SLA is the vocal booster i have learned it get u way more treble when u put it all the way to positive 4 but the distortion increases by 400%. sub lpf needs to be 80, just play with it thats 2 quick tips i can think of
  4. aznboi3644
    actually SLA is "Source Level Adjustment"
    It is only to match the output levels of the HU between the CD, Radio, and Aux sources.
    Say you have to have the volume up to level 56/62 on the HU for the Aux source...then you switch to Radio but it is super loud and distorted on Radio at volume 56/62. You turn down the SLA until the output is level with the other source.
