What "amp's" should i put with 2x orion hcca 10.4
Discussion in 'Car Stereo Amplifiers' started by bigwalla, Oct 29, 2009.
  1. bigwalla
    bigwalla New Member
    ok i got 2x orion hcca 10.4 and i would like some other peoples thoughts on this
    2 d5000 amps, 1 for each sub (dont know if this is to much for each sub?)
    2 d2400 amps, 1 for each sub (dont know if this is to less for each sub?)
    or
    4 jl 500/1 amps 2 for each sub, 1 to each voice coil?
    im in iraq and i have all the amps exept i only have 1 of the d5000, but im coming home soon and i dont know what amps to put with them? :confused:
  2. Kvo_8
    Kvo_8 Full Member
    those orions are 1500 rms each, you should be looking for an amp thats doing 3000 watts at 1 ohm
  3. eviling
    eviling Full Member
    yeah, wire them together for 1 ohm, and run it on a duel chanel or single channel amp at 3000 watts like he said. much cheaper than buying 2 amps and less pain in the ass for not having to run power lines and spliter for all that BS
