What amp for 2 RE Se12s
Discussion in 'Car Stereo Amplifiers' started by liftedranger08, Oct 13, 2008.
  1. liftedranger08
    liftedranger08 Full Member
    I think ive decided to get 2 RE se12s and build a custom ported box for them. What kind of amp do yall recommend me getting? I am kind of on a budget also, but i want it to be LOUD.
  2. cccullen
  3. liftedranger08
    Yea they are the 4 ohm subs. Will i need2 nine.1 amps?
  4. pedro quiroga
    are they dual 4 ohm coils or just single 4 ohm coils?
    1 nine.1 should be plenty. what is your budget for an amp?
  5. liftedranger08
    They are dual 4 ohm. I am looking to spend less then $1000 for amp and subs. Are the US exterminator 4000d amps any good?
  6. G3n3R@1
    G3n3R@1 Full Member
    oldschool US amps is what you should be looking into. but if you were to wire your subs down to 1ohm on a nine.1 then you would be set. but that would probably require an extra battery and all 0 gauge including the big3.
  7. cccullen
    G3, that depends on the car he has for the extra battery. x2 on wiring them to 1ohm, big three and the 0ga wires.
    NINe.1 puts out 1200watts at 1ohm at 12.5 volts. if your electrical is up to speed and your running 14.4 volts them the NINe.1 will prolly put out more like 1500watts.
    Elemental makes some solid stuff. the NINe.1 is one hell of an amp.
  8. liftedranger08
    Well, my truck is a 2000 ford ranger. I dont think it quite gets 14.5 volts, but i can get another battery if needed.
  9. G3n3R@1
    G3n3R@1 Full Member
    well would you happen to have a DMM? I can almost guarantee that you will have a large voltage drop if the nine.1 is running at 1 ohm. You'll want to perform the big 3 upgrade for the sake of your trucks electrical system.
    http://www.icixsound.com/iv/view_video.php?viewkey=2bc6f3d620bcedc94a4b
    You'll want to use all 0 gauge so heres an amp kit that I've had experience with and it worked excellent. Select the 150 amp fuse if you'll only be using the nine.1
    http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0
    As for your wire you should get between 10-15feet of more 0 gauge.
    http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX0BL
    You'll need six of these but I would get one or two extra just in case u feel like upgrading another wire or you mess one up.
    http://www.knukonceptz.com/productDetail.cfm?prodID=RT1/0516BK
    Also what battery do you have?
  10. cccullen
    couldn't have said it any better G3n3R@1
  11. liftedranger08
    Thanks guys. I have stock battery right now, but when i get my new system, ima upgrade to a red or yellow top battery up front and get a another one for the rear.
  12. liftedranger08
    When my current system is sold, ive decided to get 2 RE SX 12s with a Hifonics 2000 watt amp and put these in a box that is about 1.75 cb ft tuned to 35 hz.
  13. jonnyv713
    is that per chamber or what? thats pretty small.
  14. G3n3R@1
    G3n3R@1 Full Member
    well in the case you'll still want to do the same wire upgrades i suggested along with an extra battery. and i hope thats per chamber.
  15. jonnyv713
    i like to stay around 4-5 cubes for 2 subs.
  16. G3n3R@1
    G3n3R@1 Full Member
    i'm sure we could work with 3-3.5
  17. liftedranger08
    Yea i will be getting the 0 gauge amp kit and yes that is per chamber so around 3.50 for the whole box. Will this be a good set up?
  18. jonnyv713
    yup, 3.5 i imagine will work. when electro has some free time u should ask him to run it through bass box
  19. liftedranger08
    thanks for the help guys. I cant wait to get them. I hope they will be loud.
  20. G3n3R@1
    G3n3R@1 Full Member
    what are your goals sound wise? do you want a daily driver meaning it will be loud at most frequencies or do you want something that hits highs loud or something that can pound out some serious lows?
