Alright So If I Were 2 Run A Mono Amp 2 My 2 10 L5 Dvc 4 Ohm? How Many Watts Would I Throw At Them.and At How Man Ohms Would I Run Them At.I I Want A Nice Dependable Amp
you could either run a 4ohm or a 1ohm load with the 2 kicker L5's. The 10' L5's are 450 watts RMS a piece. so you have 900 watts to play around with. Rockford Fosgate® - Woofer WiringWizard So just like Azn and pedro said, let us know how much you are willing to spend and we can throw some suggestions your way.
POWER ACOUSTIK PS2-1600 WATT RMS 2 CHANNEL AMPLIFIER 06 - eBay (item 150207212158 end time Jan-24-08 12:05:52 PST) for not too much money this amp will work just fine. i had 2 power acoustik amps, and they did thier job with no probs at all. you dont have to run them at 1 ohm.some amps can run too hot @ 1ohm.just ask electro.lol 15 fans per amp.lol. sorry electro.jokeing
dont want 2 spend more than 220 but i want an amp that will push the 10's with out even stressing it how about this kicker is 2 much or can it take it Kicker 06ZX750.1 RMS Power: 750W x 1 @ 2 ohms RMS Power: 375W x 1 @ 4 ohms THD at 4-Ohm RMS Power: <1 % Speaker Level Inputs Preamp Outputs LP Built-In Crossovers Bass Boost: 0 - 18 dB Frequency Response: 25-200Hz Signal to Noise Ratio: 62 dB Advanced chassis with extruded aluminum heatsink Efficient class D circuitry Top-mounted controls KickBass 0-18 dB variable bass boost at 40 Hz Variable 50-200 Hz low-pass crossover with 24 dB/octave slope Defeatable 25 Hz subsonic filter High level or low level inputs (125mV-10V) PreAmp Signal Transfer (PAST) RCA outputs Delayed turn-off logic circuit Soft start turn-on circuit for reduced startup load Short circuit, Over-voltage, Reverse polarity, Thermal overload (SORT) protection Included remote KickBass control Fully CEA-2006 compliant specifications for real-world power Warranty: 1 Year Onlinecarstereo.com warranty. 1 Year warranty from Onlinecarstereo.com implies that repairs must be returned to Onlinecarstereo.com, not the manufacturer. More information can be found in our help section under returns & warranties.
ok that amp would be perfect for 1 of your subs,but dont forget you have the 2 of them and your choices are either a 1 ohm mono load or 4 ohm mono load.that amp in 4 ohm mono wont give you the power you are wanting,and that amp is not 1 ohm mono stable.
alrigh i need opinons on hifonics r they a good strong dependable amps cuz i saw 1 that might jus do i think its over rated but i want 2 know wat u guys think Hifonics BXi 1206D 1200 Watts Brutus Mono Amplifier RMS @ 4-Ohm: 1 x 450-Watt RMS @ 2-Ohm: 1 x 900-Watt RMS @ 1-Ohm: 1 x 1200-Watt Hifonics New Illuminated Heat-Sink Design With Blue LED Light Pumps Hifonics Blue Illuminated Logo Maxxsonics Illuminated "M" End Panel Logo Heavy-Duty Ultra-Fi™ MOSFETS Highly Efficient Super D-Class Amplifier Circuitry With Oversized MOSFET Output Fully Adjustable Accu-Cross™ Crossovers ±18dB Variable Bass Equalization @ 45Hz 180° Variable Phase Control (15 to 35Hz) Dash-Mountable Bass Remote Control Included Variable 24dB Subsonic Filter Brutus Pulse Wave Modulated MOSFET EXVP (Exponential Vari-Power Supply) Twin-Turbo Torroid Coil Design HSMD Hifonics Surface Mount Design Balance Line Inputs for our 18-Volt Line Drivers RCA Line Output for Amplifier Daisy Chaining Gold Oversized 2-Gauge Power Connectors Power From The Gods Included
hifonics is a good brand.it will work just fine. thats why i'll never get rid of this one.it's got to be atleast 20 years old and works 100%.
I had i thread regarding Hifonics and everybody said that they are good amps especially for the price.
how much do u guys think the brutus is really pushing out hifonics never really caught my attenetion i dont know y i jus did reall think they were really good amps
POWER ACOUSTIK OV1-2000D 2000w MONO CAR AUDIO AMPLIFIER - eBay (item 280192980954 end time Jan-23-08 13:13:40 PST) ok.for the money.i know these amps put out some power. ok.this guy runs the 3000d's 6 of them for a total of 13,500 watts,and two 600 watt amps for his mids and highs. he has never had any probs with these amps and they put out some f'ing power to those subs.
well those PA amps are fused at 60 amps...from my calculations they should be able to put around 600-700 watts rms with a perfect electrical
which 1 would b more dependable and which 1 do u guys think hit harder the hifonics or the power acustic
