wat am i looking 4
Discussion in 'General Car Audio Discussions' started by Adrian, Jan 14, 2008.
  1. Adrian
    Adrian Full Member
    so if i wanted 2 get a mono amp 4 my 2 10 L5's dvc 4ohm and i wanted 2 run them at 1 ohm would this mean am i gonna look 4 an amp that has 900x1
    @1ohm or 450x1 @1ohm
  2. G3n3R@1
    G3n3R@1 Full Member
    assuming each handles 450rms then 900x1@1ohm is what u want.
  3. pedro quiroga
    what ever you get.make sure its a GOOD brand.not a cheap amp that says 2000watts and it only costs 69.00.
    what is your budget?
  4. Adrian
    Adrian Full Member
    that db drive is around my budget dont think ive herd about bd brive, but that clarion does it have the power 2 push my tens
  5. aznboi3644
    that db drive amp is a little overrated but will still work
  6. Adrian
    Adrian Full Member
    well how much overrated and is it a dependable amp
  7. pedro quiroga
    all the amps i put up have the power to push your tens.
    the amp you see in the pic is rated at 40x4 @4ohms 12v
    55x4 13.8v 4ohms
    110x4 2ohms
    160x1 4ohm mono sub ch
    220x1 2ohm mono sub ch and thats whats running my ten,and it hits hard.
  8. pedro quiroga
    this guy runs db and has no probs hitting mid 150's and he has had the same amps for some time from what i hear.
  9. aznboi3644
    fused at 60 amps and a class AB
    60 amps times 14.4 volts = 864 watts INPUT
    864 watts input times 60% efficiency = 518.4 watts continuous OUTPUT in perfect conditions
  10. pedro quiroga
    huh..my amp?
  11. Adrian
    Adrian Full Member
    so wat would b better an overrated db drive amp or a overrated ma amp
  12. danracer
    danracer Full Member
  13. Adrian
    Adrian Full Member
    **** that way over my budget
  14. danracer
    whats ur budget??
  15. aznboi3644
    not your amps Pedro lol
  16. pedro quiroga
    ok then what was this?
  17. aznboi3644
    the DB drive amp you linked
  18. pedro quiroga
    oh ok.....
  19. G3n3R@1
    G3n3R@1 Full Member
    lol easy guys
