I recently just bought a vr3 200 watt 2 channel amp and whe i installed it worked for about three days along with that it always would shut off because it would overheat. well now it doesn't work all i get when turn on the power is a red light and that it random times i will get a 2sec green light then back to red whats goin on. Does anyone know what the problem is?
Is that the amp from walmart?? If it is the amp from walmart than your problem is that the amp sucks balls and is as good as a paperweight
Get the best amp you can afford...the amp is the basis of your system basically...its what powers your speakers. What is your budget??? What are you looking for in your sound system??? What do you wanna upgrade in your system??? What do you have so far??? How much can you spend total???
Disconnect the speakers from it and see if it turns on as it shouild, if not, toasty critter most likely.
are the subs from walmart too? Cause the motors might be trying to chew on the voice coils. that would definitely throw an amp into protection mode.
