I have a Viper audio 2500.1 amp. Its getting power on both blocks. Lights work (except the status light and protection light) which Im not sure if they ever worked., RCA's work, but i get nothing out of it. I hook everything up to another amp and it all works. Any suggestions as to what the problem may be.
so you hooked another amp to the same connections that you made and the other amp worked? Have you checked the fuses inside the viper amp? I may be a dumb question but some people overlook it...
Correct. All i did was change the amp out for another without changing any wires. I checked the fuses in my fuse block they are goood. There are no fuses on the outside of the amp and when i took off the backplate of it there were no fuses inside from the back either. I didnt remove the board to see if there were any under it??????
there shouldnt be any fuses under it, but it wouldnt hurt to pull out the board and look for burnt spots.
