Ok guys its time the ETC gets a major overhaul. Ive bought up everything i need to begin heres the deal. Shes a 97 ETC 2 door, bose system factory, but i have rewired it. Im installing a pioneer avic n1, infinity kappa perfect 6.1s up front and keeping my kicker kx 6x9 3 ways and my jls. The front had bose speaker pods houseing 4 inch speaks and no tweeter placement. I have never done any custom build work myself and need major help. I need to build a set of plates to replace the speaker pods and be big enough for the 6 inch speaks, i know for a fact that if i dont use spacer they speaks will hit against the window tracks. i dont have the tools to make the pods. anyway i can get you guys to fab me up something. also i want to mount a center channel speak, but i have no idea where i can do this...
COuld you post a picture of the door panel? I can do anything as far as cutom "pods" or "buildouts" or "door integrated" enclosures, or whatever you want to call them. But usually The car needs to be on site for the job to be done properly
sure thing pic in a sec what about the center channel... no room in the dash... arm rest dont look good either... edit dang nvm my sister is asleep and its her cam idk where its at... i will post tomarrow thanx man
A center channel can sometimes ruin the imaging of a car, and other times make it come alive. But usually in my experience it does not justify the work involved. My suggestion to you is simply get the front stage done the way you want it, and then do some critical listening. If you feel you want or need a center channel, then get a cheap 3.5 inch speaker, put it in a small enclosure (dampened tin can) and wire it up mono with a switch in line with it. Experiment with placement, and turn it off and on for instant A/B comparisons. Also, inverting phase to it can have some "interesting " effects. A center channel is very difficult to ACCURATLY make sound good. One more thing, I have found over the years tht it should play in the area of approximately 800Hz-5KHz, again just a good starting point. Overall, worry about the center channel last, you probably wont even need it most likely!
sounds like a plan. in my moms caddy and my dads (he has an 8 speaker 4.1 bose system in 98 sts greatest system ive ever herd stock) both have centers mounted in the dash and i thought it really sounded good hence why i was lookin for a way with my small 2 door lac.
But you have to think that all those systems were disigned with the help of computers and some genius math guys to figure out the placement, timing, etc. Probably way out of most peoples capabilities on their own.
I'm going to agree with The Viking on the centerchannel. A center can fix alot of problems for example if a sound stage is to wide (because the speakers are mounted in the doors), a center will narrow the sound stage but then it adds a whole new problem. Position across the stage is good from left to center but then from center to right its all bunch together. Centerchannels need a little work to get right. For me, larger speakers make the best center (6-1/2) but nothing that makes highs. For me (your car will be different) the center covers up to 1200Hz. No high pass filter. And its out of phase (270-degrees). I took a little experimenting to get it right. Three 18dB per octave filters, two 12dB per octave filter and one 6. Thats just to find the right crossover. But for me it was worth it. To do custom work I would need the car, sorry. If I remember right the Bose pod has a slightly larger than standard 4-inch opening in the pod. I kind of remember a slight gap all the way around a normal 4-inch speaker when put in the Bose enclosure. I need to see a pic of the Bose pod, would it be possible to mod it so that a 6-1/2-will fit. I would like to keep the enclosure if at all possible.
yes you are right the pod is slightly larger than a 4 inch speak almost like 4 and a 1/4. anyways pics should be up 2night thanks for all the help so far guys!
