vented design help with a 10" kicker comp
Discussion in 'Subwoofer Box and Custom Fabrication' started by cccullen, Jul 24, 2008.
  1. cccullen
    Need you help.... I need a simple vented design for 1 kicker comp 10".
    Max measurements are width 33 depth 16 height 14. It doesn't have to be that bod though. again those are the max measurements.
    Hope you can help me out....
    Thanks.
    so like a 3.0 cuft box?
  3. cccullen
    i was looking at the kicker site and they said 1.75 cubes it the max needed.
    I really have no idea, i'm a retard when it comes to box designing. lol
  4. pedro quiroga
    designing or figuring volume?
  5. G3n3R@1
    G3n3R@1 Full Member
    whats the exact model of the subwoofer?
  6. cccullen
    both...lol
  7. pedro quiroga
    W x H x D = ? then divde by 1728 thats what 1cuft is and you get your volume. also subtract wood thickness. 3/4= .75. 7/8's = .875 thickness.basicly every 1/8th = 12.5.
    so my probox is 29.5 x 16.5 x 11 od i think its 3/4's thick.
    inside is 28.75 x 15.75 x 10.25 =4641cu in divide by 1728= 2.685 cu ft
  8. cccullen
    Thanks, i do actually know how to compute for sealed. It's really not that hard. I probably want to go with either a 2 cu ft sealed box but I'd rather go with ported which i cannot design myself.
  9. pedro quiroga
    go with the specs of my probox.
    29.5 x 11 x 16.5 OD
    3/4 in hdf. port is 4 in wide x 18in deep. 3in tall.
  10. G3n3R@1
    G3n3R@1 Full Member
    also be sure to measure down the center of the port for the length.
  11. pedro quiroga
    might sound good with your sub too
    sorry its about 8 inches wide 18inches deep.
  12. pedro quiroga
    crap i cant figure out the port displacement.
    i keep coming up with .06 cu ft. that cant be right
    .75 in thick x 8 wide x 18 long. i guess im just too tired. lol
    then that makes the box 2.64 cu ft - .06(port) then 2.57. would the sub take up the .57 to make my box an even 2.0 cu ft(.assuming a wood thickness of .75 inches. so its 28.25 x 15.75 x 10.25.)
    i must have screwed the #'s on the other post so i deleted them.
    i was never good at math.
  13. jonnyv713
    arent u forgetting a measurement? height...
  14. pedro quiroga
    the wood thickness is .75 inches.
  15. jonnyv713
    i got .162841796cuft. lol
  16. jonnyv713
    7.25x17.25x2.25=281.390625/1728= .162841796cuft
  17. pedro quiroga
    the wood in the port is 8 x 18 x .75 thick.
  18. pedro quiroga
    **** i'm lost!
  19. jonnyv713
    its 3 in tall tho! lol CUBIC FEET. cube = 3 different measurements not including wood thickness.
