Two Days
Discussion in 'General Car Audio Discussions' started by Ranger SVO, Jul 2, 2007.
  1. Ranger SVO
    I have two days to build this system. I can pull it off.
    The door speakers are first, I need a little dynomat. I don't like bolting any speaker directly to a metal door
    I didnt sell the equipment, I personally would have picked the Polk Audio over Infinity any day of the week. Infinity are well built speakers but the crossovers suck
    Notice the tweeters are pointed away from the driver
    I like to put the crossovers wher I can find them for easy problem diagnosis if I should have a problem. I dont have to remove the door panel to access the wires
    More to come in a minute
  2. Ranger SVO
    Next the wiring. All of it. Because once the box is in place running anything can be difficult. The door speakers will be amped and of course the one subwoofer, so speaker wires, RCA's and everything else is run
    Next I trial fit
    And finally I build the box and amp rack
    I almost always do the baffle board last. Now I trial fit again. Everything is checked and double checked, final assembly needs to go smooth
    So far everything is going according to plan, except the woofer isnt here yet. The radio is wired up, not yet installed. I'm waiting on one other part, a USB to Ipod cable.
    The alarm is also ready.
  3. ibanezFreak87
    ibanezFreak87 Full Member
    Ranger, you are a god
  4. aznboi3644
    Ranger...Next summer I may get a internship in Dallas/Forth Worth at Lockheed Martin. Where in TX are you at???
  5. pedro quiroga
    looking good.
  6. Ranger SVO
    About 180 miles away in Abilene
  7. electrolytic
    electrolytic Full Member
    Sweet, you make it look so easy lol. Nice job!
  8. Ranger SVO
    OK I cannot stress the importance of running all the wires right at the start. Nothing is worse than having to take it apart again because you need to add something
    RCAs, Plug even the USB cable is at the back of the radio.
    The alarm also got finished up this morning. Biggest mistake people make is that they try to install it one wire at a time. Here is what I mean, locate EVERY wire you need before you take the alarm out of the box. Plan the routing of every wire before the actual install begins
    The woofer came in today so I cut the baffle board
    More to come
  9. G3n3R@1
    G3n3R@1 Full Member
    let us know how that shallow mount sub sounds, i've heard they're not that great but i've had yet to hear them.
  10. Ranger SVO
    They actually sound really good, even ported in a really small enclosure. Never tried one sealed yet.
    Almost forgot the port, actually it was gonna be a sealed box, but according to Pioneers specs it would work with a port as small as 3-inch
    I have to see it to believe it, but there it is, a three inch port.
    Its finally together
    and covered
    And its getting put into the truck
    And all of this and I still had other things to do. Oh No, this was not my only project. How about a factory cruise control switch hooked to an aftermarket cruise. This truck had no cruise control, so I switched out the factory handle with one that had the cruise buttons on it and installed the Rostra Cruise Control. Now I cannot take credit for this one, some guy named Michael at M&R Electronics figured this one out. I like smart people
    That white plug in the back will actually plug into an aftermarket cruise and it worked.
    What a day
  11. sl0wm03
    sl0wm03 Full Member
    That is really looking good so far
  12. G3n3R@1
    G3n3R@1 Full Member
    is that molex connector from something like a computer power supply?
  13. Ranger SVO
    Similar. Good eye. By having a plug we can easily diagnose any weird problems should we have any. Most of the time we don't. Projects like the cruise controls are very well thought out in advance. The one thing I don't do is magnets on the drive shaft, all modern cars have a speed sensor and that what we tie into.
    The truck was picked up and it did sound really good. The Polks in the door would have done a better job but over all I was happy with it. Everything worked first time.
    The radio was a Pioneer DEHP 6900UB
  14. TheViking
    Nice job Ranger!
    The 3 inch vent should work fine, I used small vents in those truck boxes all the time. Usually had good results , occasionally it didnt and changes had to be made.
  15. Ranger SVO
    The only thing I was concerned about was port noise with such a small vent. I was actually amazed that I heard none. I am not gonna change my minimum port size for a 12-inch speaker (4-inch port) but this speaker is definately a special case. I need to look into it a little more.
