Two 12 W6v2 Help!
Discussion in 'Car Stereo Amplifiers' started by tepa13kreeper, Aug 25, 2008.
  1. tepa13kreeper
    tepa13kreeper Full Member
    I HAVE 2 JL AUDIO W6V2 12" I WAS WONDERING IF THIS AMP ITS TO MUCH FOR IT ITS A 2000W HIFONICS BX2005D THESE ARE THE SPECS FOR IT # RMS @ 4-Ohm: 650-Watts
    # RMS @ 2-Ohm: 1300-Watts
    # RMS @ 1-Ohm: 2000-Watts
    # Adjustable Bass Equalization
    # Remote Bass Control
    # Built-In Crossover: Low-Pass, Band-Pass, Full, Hi-Pass
    # Channel Separation
    THESE ARE THE SPECS FOR THE SUBS
    # 12" W6 version 2 Dual 4-ohm subwoofer. Nominal Diameter: 12 inches (300 mm)
    # Continuous Power Handling: 400 Watts RMS. Voice Coil: 2.75" diameter, 4-layer, Kapton former.
    # Xmax (one-way, linear): 0.65" (16.5 mm). NeckVent? Technology.
    # VRC? Technology, W-Cone? Technology, Elevated Frame Technology, Floating Cone Attach Technology.
    you can wire them into a 4 ohm load with no worries.
  3. tepa13kreeper
    how would i do that?? i dont really know much about car audio if you can help me i would really appreciate it
  4. cccullen
    here's how you should wire them up to get a 4ohm load.
  5. cccullen
    in my opinion though I wouldn't get that amp. I would be looking for an amp that would probably give you 800 watts at 1ohm or an amp that will give you 800 watts at 4ohms.
    the problem with the amp you picked is that if you wire the subs into 1ohm it's way too much power and you'll risk frying the voice coils.
    Did you already buy this stuff or are these just suggestions? What's your budget?
  6. tepa13kreeper
    i already bought all this stuff i got 2 12 w6v2 hooked up to the hifonics http://ampguts.realmofexcursion.com/Hifonics_Brutus_BX2005D/ <~~same one i got can u tell me what amp will be perfect for both of these subs and how to wire please im new at all this just want it to sound good with out damage
  7. cccullen
    well, since you have it already just wire you subs like the diagram i attached above. that will put you at a 4 ohm load. you'll be giving 325watts per sub. you should be fine like that and your amps should run VERY cool that way. Hifonics are 1ohm stable but your subs can't handle that kind of power.
  8. tepa13kreeper
    what about jl audio 500/1 will it be better than the amp i got now for the subs??? .............ok if i wire the subs the way u said i will just use one connection at the box?? or how do i do that
  9. cccullen
    650 watts is plenty of power. Just use one terminal at the box. your amp probably has 2 sets of connections but you just have to use one set, it's all connected as one inside the amp anyway.
    Hifonics is a lot cheaper than a JL amp. If it were me, I would just use the Hifonics.
  10. tepa13kreeper
    Im Going To Trade My Amp On Craigslist Wich One Do You Recommend I Get For The Subs
  11. cccullen
    I would just keep the Hifonics if i were you. no need to trade it. It's a good amp. what kind of box are you going to use for your JL's? sealed? vented? are you making your own or buying a ready made?
    I would be more concerned with the box than anything. the kind of power you are pushing to your subs doesn't mean a thing if it's in a crappy box.
  12. pedro quiroga
    the amp you have now has more power than the 500/1. unless you want an a jl set up keep what you have. that way you have the ability to upgrade to more power in the future.
    you wrote that you keep blowing fuse's. how big is the fuse under your hood?
    make a list of all your equipment so we can better help you with your problem.
  13. pedro quiroga
    ignore the last post^^^. i didnt see the other thread before i read this.
  14. tepa13kreeper
    i have a sealed box im not sure if its to jl specs ill take pictures of it tomorrow and post it i was running 100a fuse under the hood thats the one that keep blowing
    this its my whole set up
    i got a optima battery
    going to get a 150 fuse under hood
    jvc stereo not sure what model
    alpine type r 6 1/2 and component
    alpine type r 6.9
    jl audio300/4
    hifonics bx2005d
    2 12 w6v2
    sealed box
  15. tepa13kreeper
    so would i have to drill a whole in the middle of the box to pass the speaker wire from one sub to the other?
  16. tepa13kreeper
    is this how it should be connected i tried to draw my set up but it came out bad
  17. cccullen
    you got it right.
  18. cccullen
    yup, the 100a fuse was too small for what you have, that's why is kept blowing. What kind of bass do you want? most of us around here use ported cuz we like really loud bass.
  19. tepa13kreeper
  20. cccullen
    ok, the good thing is that your hifonics has two sets of terminals, right? if so then you can wire it up that way. Anyway, the Hifonics mono amp was made to make installation a lot easier so you can do it that way.
    your Hifonics isn't a 2 channel amp. it a mono amp but has two sets of terminals, they all meet up as one in the inside
