After putting my subs in my new car acceleration has become a bit more sluggish than I like. I am thinking of moving down two a single Armageddon in a sealed enclosure. I know I WILL be loosing alot of output, but I fear for my hearing. :unsure: I looked up what Kove reccomended for my sub. They reccomended 1.75 cubic feet, 16 F3 hz. The internal dimmensions are: W X H X D 20 17 9 What would you guys recommend? I am looking for SQ mostly. I just wondered if this was the best box for SQ. I kinda doubt they are SQ drivers though. Also is there anything lighter than MDF that I could use? I have run into a problem, how would I run my JBL 1200.1 @ 4 ohms with a dual 4 ohm voice coil sub? Is there some kind of series/parrallel combination that will allow me to do this? Could I just keep the gains all the way down? Or will I have to get a smaller amp? Made up a small table because my sub isnt in Winisd. Model FS (Hz) QTS QES VAS (lits.) SPL db (2.83 v.) XMX (mm) Z nom (ohms) M 15D 28 .50 .56 108.78 89 15.00 2x4.00 RMS (watts) Mounting Depth (in.) 500 7.00 Thanks in advance!
