The wicked one lives
Discussion in 'Subwoofer Box and Custom Fabrication' started by ramos, Jun 20, 2006.
  1. ramos
    ramos Full Member
    A while back, I was discussing the importance of enclosure design with a friend. I made the statement that even crap subs can sound decent, and get loud in the proper enclosure. He scoffed at that statement, saying I was full of it. I told him to put his money where his mouth is and place a wager on it. So started the bet. $100 If I could make a sub(s) under $50 each sound better, and be louder than his 2 12wo's in a prefab with 125w each.
    His two w0's did a 129.7 sealed in the kicks on the tl. Sounded decent, but nothing to write home about.
    So being the smart arse I am, I went on a quest to find the cheapest subs I could find.
    Paid a whopping $1 for the par at a yard sale. Figured couldn't get much cheaper :D
    Then started on the enclosure. Wanted high efficiency, and clean sound. Enter the wicked one
    Results, flat frequency response from around 30 to 100hz. Powered the pair of 8's with a kicker kx250.2 . Pulled a 136.3db in kick on the TL . And happily took my $100 and bought us some beer to drink while I built him a new enclosure :D Just goes to show 5% product, 90 % installation, and 5% beer :)
  2. CadillacETC1997
    nice install however damn it will suck if you wanna swap subs in there how do you do that cuz if im seeing this right they are mounted inside the box and cant even be seen.
  3. ramos
    ramos Full Member
    Yep , they are inside. Top panels is attached with screws, and weather stripping for easy removal if I need. But not really concerned with removing them. This was just something to fart around with. If I intended to run this set up. A couple access panels wouldn't be very hard to cut in the top :)
  4. CadillacETC1997
    very tru juz makin sure i was seein it right lol
  5. ramos
    ramos Full Member
    Yep your seeing it right. :D Have to go to great lengths some times to prove a point :)
  6. CadillacETC1997
    hey you made 100 off it id say after your labor and parts you prob broke even ahhahaha
  7. ramos
    ramos Full Member
    It was worth it . Makes a pretty nice coffee table :D :)
  8. TheViking
    Excellent post!!!!!
    I have said the SAME thing for YEARS!!!!!!!!!!!
  9. ramos
    ramos Full Member
    Thank you , great minds think a like :D seen to many people put a lot of money in equipment and then half arse the install. Only to be dissapointed :)
