The Batmobile 4th order! 2 18's!
Discussion in 'General Car Audio Discussions' started by kryptonitewhite, Jul 18, 2010.
  1. kryptonitewhite
    kryptonitewhite Full Member
    What subs should we use for 4th order BP? We want a LOW tune around 25Hz-30Hz. Plenty of airspace available, 2 20"x20" square ports. 2 18's. Run off either one or two AP30001Ds.
    i know i kid that runs 2 kicker 18's tuned to 25HZ and his **** digs super deep. sounds good too.
  3. kryptonitewhite
    that was the orignial plan, solox 18s
    apx. 10 cu ft for the front (vented) chamber and apx. 20 cu ft for the rear (sealed) chamber. 2 10" ports.
  4. kryptonitewhite
    Exodus Audio Maelstrom-X 18"
    1) Speaker Parameters
    Diameter: 18.00 (inches)
    Qts: 0.37
    Fs: 17.40 (Hz)
    Vas: 11.05 (cubic feet)
    = 312.90 (liters)
    S: 0.70 (response curve - .4 thru .7)
    2) 4th Order Bandpass Cabinet Parameters
    Lower 3db Rolloff: 20.00 Hz (F3 Provided by user)
    High 3db Rolloff: 53.89 Hz (Calculated)
    Sealed Box: 4.32 cubic feet
    = 7458.70 cubic inches
    = 122.24 liters
    Ported Box: 2.96 cubic feet
    = 5122.98 cubic inches
    = 83.96 liters
    Tuning Frequency: 32.83 Hz
    3a) If using a Single Port
    User definable port size:
    Port Diameter: 8.00 inches (203.20 mm)
    Port Length: 36.47 inches (926.43 mm)
    Suggested: (.3 X Speaker Diameter)
    Port Diameter: 5.40 inches (137.16 mm)
    Port Length: 15.33 inches (389.47 mm)
