/ Register
Tempest
Discussion in 'General Car Audio Discussions' started by MeRSC, Feb 9, 2004.
  1. MeRSC
    MeRSC Full Member
    i have an amp with 720wrms and i'm looking at getting a 15" sub for $150 or less. the tempest looks like a great pick. but i've heard it can't mechanically handle 720wrms. should i give it a small ported box, so it won't blow? if i do, would it still be able to "tune" to 20-25hz?
  2. ScottS
    ScottS Full Member
    Depending on the box you put it in it will handle that much power. I personally have ran over 2000 rms to one tempest.
    Scott Stoner
  3. black00
    black00 Full Member
    ya...whoever told you that was a halfwit...
    Myself...i've choked one with over 1500 ....still wangin to this day...
    I'm pretty sure nobody has beaten on those woofers more than i have...
    They can take it...just build the box properly...
  4. Steven Kephart
    Steven Kephart Full Member
    I think you are looking at it wrong. Don't think of it as not being able to handle that power, but not needing that power. :yes:
  5. MeRSC
    MeRSC Full Member
    so it can take the power if i build the box right? how do i build the box right? i'm a newb
  6. The_Ancient
    The_Ancient Full Member
    exactly, once you get to a certin point, your just adding heat, and not gettting any more sound,
    but the tempest is rated for 750w rms, so no 750 would not be over powering it,
    also. like witn any subwoofer, that rating is THERMAL, not mechincal. box size in the detriming factor
  7. MValley70
    MValley70 Full Member
    What type of amp is the 720 coming from....just curious...might not really be 720 watts
    Scott, SC
  8. MeRSC
    MeRSC Full Member
    uh the amp is a Kole hk1440-2...
    2channel amp (tehy say max is 1440 watts)
    300@4ohmsx2
    360@2ohmsx2
    720bridged
    ok so the box size is the detirmining factor? i was looking at a sealed box tuned pretty low.. how do i know how big to make it. also, from visionary forums under adire products. they say the magic box is 4ft ported... what do you suggest?
  9. geolemon
    geolemon Full Member
    This is really precisely it...
    If you are looking to tune it THAT low (20hz), have you considered simply running it in a sealed enclosure?
    Although, it will mechanically handle more power, in the ported enclosure, particularly running it tuned quite low (20hz-25hz).
    What sort of sound quality, and output level are you looking for?
    What kind of musical tendencies do you have?
  10. geolemon
    oop, I didn't scroll far enough, I guess, before I replied... :p
    You don't really "tune" a sealed enclosure.
    You can manipulate the size of a sealed enclosure, to manipulate the frequency response shape, the damping properties, and the efficiency of the subwoofer...
    But you don't "tune" it, like with a ported enclosure.
    With a sealed enclosure, as you increase your enclosure size, you:
    * Increase the damping properties of the sub
    * Increaes the low-frequency capabilities of the sub
    * Increase the efficiency of the sub (same output levels on less power)
    With a ported enclosure, you incorporate a port... which has a given port size, and length...
    When you manipulate the size and length, you "tune" the enclosure to resonate at a given frequency...
    If tuned low, the port can be used to extend the response lower.
    If tuned high, the port can be used to create a big peak in the response, boosting SPL around that peak.
    If SQ is your primary goal, the sealed box is probably your best bet, as it has a gently sloping roll-off that typically combines in a complimentary way with your car's cabin-gain, yielding a nice-flat in-car frequency response.
  11. geolemon
    Oh, and if power is a concern, you can always artificially throttle-back the amp, by running the gain control even lower than you technically might need it.
    But I really don't think you'll have a problem, even with the full 720w.
  12. MeRSC
    MeRSC Full Member
    thanks for your help.. i went ahead and ordered a tempest. and decided to go with the 4'cubed with the 12" vent (4'diam). with the gain setting lowered.. i think it will be fine... thank you for telling me the full 720 won't be a problem! i was tired of CAF... they all told me different things... i think that's just a newb forum compared to here..
  13. geolemon
    Well, this is a good forum, I agree there! :D
    There are good and bad things with a forum as big as CAF...
    Both related to traffic.
    Things move very quickly there, that's good.
    But in the same sense, with so many hands in the pot, odd stuff is bound to sometimes get added and stirred up... :rolleyes:
    What was said over there that didn't seem right to you, btw?
  14. MeRSC
    MeRSC Full Member
    there isn't one particular thing that i recall, but many times things were said that even i knew were wrong, from people that esteemed themselves highly.
  15. The_Ancient
    there is only one things you need to remember, what I say is Correct, anyone that disagrees is wrong.....
    Remeber that, and if you disagree, well............. your wrong too :p :p :p :p :p :p :p
  16. sandt38
    sandt38 Full Member
    Just remember this in your forum travels. I am never wrong.
    PS, next time you order an Adire product and it is not from my store, I will be forced to ban you :ban:
  17. The_Ancient
    no seth, only when you agree with me are you right, when you disagree you are wrong
    jeeze I have to teach you everything :p
  18. sandt38
    sandt38 Full Member
    Micheal, don't make me edit you :p
  19. MeRSC
    MeRSC Full Member
    sandt i didn't knwo you had a store, sorry. now i see your sig.
  20. sandt38
    sandt38 Full Member
    Just giving you a hard time man.
