hello again guys and gals. havent been here in a little while.its been kind of crazy around here.i have some new boxes so figures ide post them . these are sq plus boxes .They produce nice tight bass and do get loud. If any of you need a custom enclosure or need some help . hit me up at tech12volt@yahoo.com or check us out at www.tech12volts.com we are in our building stage on the website so please be patient. some of you may remember the isasca sqplus format. thats where these enslosure get their name. i sure miss that format. sq was king.
thank you im in ga. i sell alot on ebay . http://cgi.ebay.com/ws/eBayISAPI.dl...MESE:IT&viewitem=&item=230073978294&rd=1&rd=1 so i ship alot of stuff. i do this on the side right now. i am an instal;l manager during the day. been doing it for the last fifteen years.
i have built a few but never without having the vehcle here.i actaully did two pioneer slom 12s ported in one and it sounded great.
well since you are only 2 hours away from me maybe we will work something out then. I will email you about it.
I pulled into my garage last night and up against the wall I saw a roll of landscape fabric sitting there.....and I wondered....... Would this type of material be suited to use as mat when doing fiberglass?? I know it is pretty strong and it is made to allow water and moisture to go through it into the ground....it is cheap and easy to get..... After I saw that Ranger used "T" shirts on projects, I was just wondering what else could be used.....It just hit me as I pulled into the garage last night.... From what I gather, this is the process (basically) if you want to build something and make it fiberglass...Take the area you wish to put the enlcoure in and make a mold of it..Lay down tape of aluminum foil in that area and extend that beyond where you want the edges to stop....maybe draw a line with marker where you want the edge to be....Cover all other areas that you want to protect from the mess of resin.....Put a coating of resin and mat material down covering the surface.....Do this over and over again making several layers.....Let it dry.....Pop the mold out of the area to complete it. (use a mold release wax so the fiberglass will separate from the tape or foil) Take MDF and make a ring for the driver(s) to sit in....Place that in the area you want and make a structure to hold it temporarily with dowel rods, mdf, etc....Once the framework is set up, stretch mat (or other suitable material) over the surface and begin adding layers of fiberglass resin, mat and repeat untill you get it all done....Use body filler to smooth out everything to the final shape and then cover with material or paint..... Is this about the jist of it....basically?? Willy
Yeah that is the jist of it...but that weed matting won't work worth crap...its plastic. It won't be nearly as strong as actual fiberglass
I agree with Azn.....the resin will not soak into and penetrate (huh huh, i said, "penetrate" ) the mat, it would make for a weak structure, I dont reccomend it.
Tech12volts.com is up and running guys.Sorry i have not been around. been slammed with work which is a good thing
