System in the truck and amp trouble!
Discussion in 'General Car Audio Discussions' started by jonnyv713, Feb 6, 2008.
  1. jonnyv713
    i went outside and played with the stereo a lil bit and decided to see what it would sound like without the rear speakers hooked up, so i unhooked em and it sounded alot better. but, now i know that the sub is rattling EVERYTHING and it gets pretty annoying. i took some measurements for the new box too. i am hoping to start that when it warms up a bit. now my problem is that i need to decide whether to get new components for the rear or get some sound dampener. well, i suppose i can prolly get enough peel and seal for the doors and some of those zues components. but i also have another problem, i went to hook up my lil jensen and it went directly to protect. i made sure everything was hooked up right, and i looked inside but i didnt see anything very obvious. i took some pictures of it so u guys can possibly point some stuff out.
    Thanks guys! you're a bunch of help.
  2. jonnyv713
    and if i get the components can i run my front 6x9's off the same crossovers?
  3. aznboi3644
    no you can't....I'm not really that good at fixing amps.
    I'd take it to a local electronics repair shop
  4. jonnyv713
    i didnt really think so cause then i would lose all my fade and balance and ya. ite i may consifder that but its not really that special cause i only spent 15 bucks on it.
  5. jonnyv713
    should i just buy some seperate crossovers or bass blockers for the 6x9's then?
  6. electrolytic
    electrolytic Full Member
    Does the amp go into protect with just the power wires and remote wire hooked up and nothing else?
  7. jonnyv713
    i havent tried that i hook everything up but i will try that maybe tomorrow cause i have a b ball game tonight.
  8. jonnyv713
  9. jonnyv713
    i went out today to make a video wit the 2 ehqs's in the truck in the big 4 cube tuned to like 38hz. and when i hooked it up i bridged them at 4 ohms. i set the gain and it didnt push any air hardly at all through the ports! what am i doing wrong? it used to move air like crazy!
  10. jonnyv713
    i just connected the power, ground, and remote and it still went into protect!
  11. electrolytic
    That's a shame lol.
  12. electrolytic
    She's toasty
  13. jonnyv713
    so its done for?
  14. electrolytic
    yes, you could probably get it repaired but jensen is low end. Might want to get something better.
  15. jonnyv713
    ya thats what i was thinkin, it aint worth it, i only paid 15 bucks for it
