I'd like to get a few suggestions on what JL Audio amp(s) I should go with to run my entire system. It's been years since I have touched my system and I am giving it an upgrade. Here is what I currently have: 2 MB Quart 5 1/4 (front) 2 MB Quart Tweeters 2 MB Quart 5 1/4 (rear) 2 MB Quart 4'' 2 JL Audio 12w0 I have been tool to go with a single 500/4... what do you think?
I assume you have a 3-way set up front and some 5 1/4 coaxials in the rear? If that is correct, and you want to give amplified power to all of your speakers, including the sub, you'll need a 5 channel amp. However, if i were you, i would just run the rear speakers off of the HU power and use a 4 channel amp to run the fronts and the sub. Hope that helps...
