suggestion please help!!!
Discussion in 'General Car Audio Discussions' started by nortyhat, Dec 24, 2006.
  1. nortyhat
    nortyhat Full Member
    hey i found out today that i cant upgrade my alternator for my 2002 lincoln ls. i called the dealership and they said i have to put the factory one in. i think the factory alternator is 130amps and i have 2 jl audio 12w7 2 1000/1 amps 1 300/4 and xr jl components hooked up. so i need some suggestions now for how im going to keep my lights from dimming and my power real high? i was thinking a 25 farad power acoustik cap and a red top battery?
  2. aznboi3644
    Read the sticky about capacitors.
    A 25 farad cap will do nothing but hurt your electrical system...with two 1000/1's you are probably going to have a new alternator...just don't tell the dealership...those 1000/1s are very power hungry.
    two 500/1s or one 1000/1 can push a couple 12W7s easily
  3. pedro quiroga
    have you done the big 3?
  4. aznboi3644
    Ahh yes the big three...thanks pedro
  5. nortyhat
    what do you mean by the big 3? and also i dont know where to get one that would fit in my car and is good i heard of lestek or something. and how much amps would i need?
  6. pedro quiroga
    the big three involves adding a larger wire from your alt to your batt.adding or replaceing your grounds too.larger gauge wire.
    i can never remember what else.....its in one of these threads somewhere
  7. aznboi3644
    There is a sticky about the big three...also if you are buying a new alternator get the biggest you can afford...but make sure it puts out good power at idle
