Subwoofer help[
Discussion in 'Car Subwoofers' started by Weecrack, Jan 14, 2009.
  1. Weecrack
    Weecrack New Member
    Ok im new here, and somewhat new to car audio
    A quick break down
    alpine 1dx200 HU
    ken wood 3 way front speakers
    Kenwood 3 way rears Amped, with a Visonik 400w 4 channel amp
    Now my subs
    I have 2 8 inch solobaric Kicker l5's
    300w rms and 600w peak 4ohms
    Im goin parallel wiring on this for a Hifonics Bxi1208d amp 1200w @ 1ohm
    Ok soo everythign is hooked up, to what i see and feel is correct, 4gauge power wire into a dblock, my ground a 4 guage ..
    The visonik amp turns on the speakers work, it sounds great, nice and loud, clear
    The Hifonics amp turns on, No issues, but i hear no sounds whatsoever...
    None at all
    Can anybosy trouble shoot me some possibilities of whats doin this?
    I switched rcs, nothing
  2. aznboi3644
    check the signal cables
  3. Weecrack
    Weecrack New Member
    I had a friend look at it, and we switched the rcas that work into the amp and still nothing...
    he also took out the box and put it in his car and it works soo were thinking it maybe the amp
  4. cccullen
    the amp powers on but no sound? why don't you try to hook your amp in your friends car to see if it works there?
  5. jonnyv713
    Ya, what he said^^^
  6. Eleu
    Eleu Full Member
    Well, check the rca's for signal comming from the first amp, thats your starting point is your losing signal somwhere, could be in the daisy chain of the two amps. if they have signal then move to the next point of entry. work it out from there to the rca outs. also check the input voltage of the second amp, it might require higher thn what the passthrough on the first is feeding.
  7. Weecrack
    Weecrack New Member
    If the input voltage inst enough wouldn't the amp not turn on? or go into safety ,mode?
  8. G3n3R@1
    G3n3R@1 Full Member
    He's talking about your RCAs not your power. Your RCAs are measured in voltage. The higher the voltage the lower your gain will need to be set. if the voltage is too low then the amp won't be able to make anything of it even with a lot of gain.
  9. Weecrack
    Weecrack New Member
    Soo how do i check that?
  10. G3n3R@1
    G3n3R@1 Full Member
    Try hooking your RCAs straight up to the hifonics first.
