subs connection to amp
Discussion in 'Car Subwoofers' started by Ads vecs 7, Jan 31, 2007.
  1. Ads vecs 7
    Ads vecs 7 Full Member
  2. TheViking
    It appears that the subs are wired series, so each speaker will be an 8 ohm......(assuming each voice coil is 4 ohm). Next the subs are each wired together in parellel by the jumper wire on the outside of the box.....this will create an effective 4 ohm load to your amp...
    by the way, thanks for the pics! Wish more folks did that, makes it SO much easier to help out!!!!!
  3. Ads vecs 7
    so if i ran the one speaker cable to the amp how would i connect it?
    bridge or 1 channel etc?
    or should i connect speaker cables to each side of the box and run it through 2 chanels?
    it used to have just the one pair of wires running from my sub to the amp
  4. Ads vecs 7
    any help please?
  5. aznboi3644
    What impedance are the subs??
    I'd wire it all up parallel parallel to the amp if the subs are both dual 4 ohms
