Subs & Amp Package - Comp Spec
Discussion in 'Car Audio Classifieds' started by AzidRush, Jan 12, 2009.
  1. AzidRush
    AzidRush New Member
    Hey guys
    selling my subs and amp package I have. It is pretty much comp spec, not brand new but still extremely good setup.
    It consists of 2 x 12" kicker compvr subs in seperate single boxes and a fusion 4 channel 500w fp4-500x
    specs below
    subs:
    12" sub with dual 4-ohm voice coils
    suitable for marine use
    injection-molded polymineral cone
    double-stitched, foam-ribbed Santoprene rubber surround
    frequency response: 25-500 Hz
    power handling: 50-400 watts RMS
    peak power: 800 watts
    sensitivity: 86.7 dB
    amp:
    65 x 4 into 4Ohm
    250 x 2 into 4 Ohm
    You can run the front channels separate and bridge the rear two.
    Like I said pretty much comp spec and certainly crank nice and loud with no fizzing noises, its a nice crisp bass sound. If i wasnt flying overseas in 2 months id definately be keeping this setup
    will provide all amp and sub wiring including fused power cable to run from car battery to boot
    Price: $400
    Pick up from newcastle as I do not want to post, will travel one hour in any direction from newcastle for $20 extra
