Sub install on stock headunit
Discussion in 'General Car Audio Discussions' started by ibanezFreak87, Sep 18, 2006.
  1. ibanezFreak87
    ibanezFreak87 Full Member
    How does one install subs on a factory bose headunit?
    The car is a 2002 Infinity QX4
  2. CadillacETC1997
    already took care of this one boys no worries
  3. TheViking
    If I was to install subs on a bose HU, I would attach them to the bottom of the head unit using duck tape and super glue, then shoot some spray expanding foam into the cd slot so as to eliminate any vibrations from the deck. then mount the whole unit to the rear bumper with the sub firing up, this will eliminate any standing waves from developing in the car, again, mount it using duck tape and super glue. Also be sure to put some stripper glitter on the woofer cone, so as to make it act as a reflector when the tailights dont work.
  4. ibanezFreak87
    wow. viking, you should be an installer. that as funny as hell!
  5. CadillacETC1997
    aww common bose aint that bad for stock
    i know you not a caddy fan but if u ever get the chance sit in a 98+ Seville with the bose 4.1 system. it really does sound great
