sub box for a kicker 15 l7
Discussion in 'Subwoofer Box and Custom Fabrication' started by magnum340, Aug 13, 2006.
  1. magnum340
    magnum340 Full Member
    hi, im new to this forum, but a long time lover of car audio! im thinking of buying a solo baric 15 l7. the recomended air space for a ported box is a minimum of 3 cu and a maximum of 6cu. i have enough space for 3cu, my question is will 6cu sound better than a 3cu? is it even worth putting it in a 3cu box? or should i get a solobaric 12 l7 and put it in the max air space which i think is closer to the 3cu. i just want it to pound. i will be powering it with a fosgate 800a2 and a fosgate 1 fared cap. and it will be in a magnum rt. any info would help thanx. jaime oh dose anyone have a solobaric 12 or 15 l7? how dose it sound , are you happy with it. how much power are you feeding it? thanx again.
  2. CadillacETC1997
    it all depends on the power your pushing if memory serves me the 800.2 pushes 800 at 4 ohms bridged for that amount of power to one sub i reccomend going like 4.5 at least
  3. magnum340
    how did you get that # 4.5 and do you know if this set up will sound good?
  4. CadillacETC1997
    larger the better depending on power levels. the sub, if im right, handels 1000 rms 2000 peak correct? and operates at 4 ohms pending on wireing? therefore you underpowering it. full rms power for full volume size. since ur running it by 200 under id use something from like 4-5, 4 on the small side 5 on the high side.
    edit:
    in answer to the rest of your Q. i dont have this sub and without actually having it i cant say for sure. when it comes down to it car audio is all really by ear, not by numbers. useing numbers however can be used to determine what probably will sound good. using that logic id say that would work best.
  5. Ranger SVO
    Absolutely. And if you don't believe him, put the speaker specs in any speaker box program ( WinISD, or BassBoxPro ) and watch what happens as size increases. I would stay within the recommended size and lean toward the larger 6 cu. ft.
  6. magnum340
    i realize im underpowering it by 200rms but this amp is a monster and i feel like it will do the job just fine, but also its just a feeling.but a good one i think!
  7. aznboi3644
    solobaric 12 inch
    3.65 cubic feet before port displacement
    2.25x13.25x22 inch slot port
    Got this from a dude on the 12 volt who is sponsored by kicker...he said this should pound pretty hard
  8. magnum340
    dam! thats a lot of space, if i wassnt married and have a babby girl i wouldnt care if i had no trunk space left, but between grosuries and the stroler i dont know about the 6cu ft. its bad enough i drive a wagon.... with a HEMI!!!. thats the only way i told the wife id drive a wagn plus its pretty cool lookin.
  9. Ranger SVO
    Now that looks and sounds reasonable, I would still go closer to 4 cu. ft.
    That recommended port has a cross sectional area of 29.8 cu. in. Two 4-inch round ports would have a cross sectional area of 25.1 cu. in and take up less space then the slot port. The 5-inch difference in the areas would not cause any problems in vent velocity.
    Just more to think about
  10. CadillacETC1997
    lol as i said figureing it out in my head 4-5 cu!
    i amaze myself haha
  11. fstrfvo
    fstrfvo Full Member
    I have a L7 12 inch in a sealed box that came form kicker. .its about 2 feet long and about a foot wide. Pushing it with about 1100 watts from an MTX 942 amp. This thing really hits hard. If you dont have the space for a ported box go with a sealed one. The sound quality is awesome and suprisingly is very accurate.
  12. magnum340
    so 4 to 5 cu is good for the 15 or 12? and how about a sealed box. will it pound like a ported box? i can build it smaller and fill it with that cotton stuff, if it works, i think its supost to make the sub think the box is bigger i think. any ideas as how manny db the 12 or the15 hits?
  13. aznboi3644
    My friend has two 15 L7's in a box we built....it is just a copy of a prefab he found at a shop...Told him I could build a bigger and better box...its only about 2.8 cubes per chamber with a slot port in the center.
    Yes its still loud as fack but the lower bass notes suffer a lot...hell we don't even know the vent tuning of the box...I hate prefabs.
  14. CadillacETC1997
    ported = louder thats their advantage
    sealed = better more tight sound
  15. magnum340
    can i get some sugestions 0n eather a 12 l7 or 15 l7 , and in a sealed or ported box. i will be running a fosgate 800a2 amp. any and all sugestions will be greate. also box size would be awsome. thanx
  16. CadillacETC1997
    umm havent we been?
    in my opinion 15s lag and in a hatchback youll hear it more. most will argue that if they lag then why are they used in a stereo comp or at concerts and such and thats becuase it doesnt matter if they lag then but they lag. that said id run 1 12 or better yet 2 10s, because im assuming you dont want to use alot of space putting 2 12s outta the question. again as i said before i prefer sealed over ported, sealed makes better quality sound, ported is just used to make it sound louder. If your running THAT amp and soo hell bent on it why the L7? The fact that you keep asking 12 or 15 leads me to believe you havent bought it yet, so why Kicker why not Diamond or Dynamic or JL?
  17. magnum340
    well jl i think is to overpriced and the other 2 havnt realy heard of. plus i have to do with the amp i have now i dont think a single jl woofer can handle 800rms. is kicker not a great choice, and if i was to go with the l7 12 sealed box can i build the box smaller and stuff it with that cotton stuff to make the woofer think its in a bigger box. dose it even work. i know it all boils down to what i want and what sounds good to me, but its nice to know other agree or disagree with me.
  18. Hautewheeler
    Hautewheeler Full Member
    ah, forget about the polyfill.. that's nonsense, use a properly built enclosure, and you'll never miss it. I lean towards a large ported box if you have the room, and the subs can handle it. - the kickers can.
    also, a large ported box (properly tuned) will "increase" the efficiency of the sub, meaning that you can get good sound with less power. and those subs are inefficient to begin with. with a smaller enclosure, you have to "push" the subs harder to get the same sound.
    if you have the room, go for it.. the kickers sound great in a big honkin box:D
  19. fstrfvo
    fstrfvo Full Member
    Basically look at the woofer you are going to get. In this case you were asking about the Kicker solobarics. You need to figure out how much louder or more efficient the ported box will be versus the sealed one. Some of it will have to do with how the ported box is tuned. If im correct it will only be louder at the frequency the box was tuned at (if im wrong please let me know). From your last post I think you are looking to save space. My sealed box for my 12 inch L7 is quite small and only takes up a small corner of my trunk. I dont think I would build a smaller box and put polyfill stuffing in it unless its a last resort, and I mean last resort. Build the box to match the woofers parameters and you wont be dissapointed.
