Sub and Amp setup?
Discussion in 'General Car Audio Discussions' started by kebas239, Feb 9, 2012.
  1. kebas239
    kebas239 New Member
    Hi guys! I recently purchased an Alpine SWR-1223D Subwoofer and an Alpine MRX-M50 Monoblock amplifier. The Sub-woofer is dual coil at 2 ohms and the amp
    is rated for 300W at 4 ohms, 500W at 2 ohms and 300W at 1 ohm.
    I realize I should have bought the dual coil 4 ohm sub-woofer to create a 2 ohm load but that time has passed, so I'm asking this assuming I'm stuck with the sub-woofer I have and that I cannot replace it.
    My questions are:
    1) What is the ideal setup for this sub and amp? According to the spec sheet, I get the same power output at 4 ohms and 1 ohms, so is there any compelling reason to make my amp produce more heat and higher distortion for no difference in output?
    2) Why would I get a LOWER power output at 1 ohm? I thought there was less resistance in the line so there would be an increase in wattage (right?).
    Thank you!
  2. kcox669live
    kcox669live Full Member
