well fellas wat do u guys think about Stinger wiring and terminals im thinking of getting there wiriing any doubts or something im gonna run 4 guage wirirng im gonna with battery terminals also so jus any suggetions
I have their digital battey terminal, it shows the voltage at the battery without having to put a meter on it and it has a VERY tight connection on the battery.
I do not like stinger ring teminals AT ALL. After 3 years I found all my stinger 0 gauge gold ring terminals were corroded and they needed to be ground down to get a funky green mess of of them. Was not just cosmetic it was actually causing noise in my system. Oddly enough only connectors that were bad were attached to these ring terminals. Crappy little tin connectors that were bolted down in a more open location were not bad or need attention. Even the 0 ga gold ring terminals that were inside of the truck needed to be grinded clean. If you use them just pay attention if they start to corrode.
hmmm maybe you got some bad ones. i had some stinger batt terminals for 16 years before i got some new ones. all the gold plating came of,but they never corroded.
these are ring terminals. had to replace 14 in my old firebird under the hood (replaced all the factory wires and underhood fuses) after 1 year (was cosmetic for IASCA) and two that went out in my truck arent even on the outsside of the truck ....
i know you were talking about ring terminals. like i said you maybe got a bad batch. you know crappy plating or something. all that funk is electrolysis i believe.
3 purchases 9 years apart all the same lol that is a big bad batch. never had issues with lightning, rockford or Knu and for the most part they cost less as well.
