These are brand new, not even a scratch. Only used a couple of times in my bedroom. FEATURES: STR8-100/ST-100 Who says you can't teach an OLD dog NEW tricks?!?!…Can your turntable do this? Play forward & reverse with the same amount of torque even at speeds up to 45 & 78 rpm? Allow you to plug directly into ANY mixer without a phono in or ground cable? How about connecting directly to your computer or other digital sampler? What about "Key Correction" changing the tempo (bpm) without changing the pitch (note)? You can even use the MP3 line in sending audio through your turntable without having to even touch your mixer. Come on DJ's Get it STR-8™...The New STANdards are coming from STANton: Completely re-inventing the wheel is not an easy job... But someone has to do it. So starting with the industry standards we have re-built the turntable, kept all of the desired features that today's DJ's need and even included some from the future. Introducing the STR8-100 and the ST-100, 2 super high torque turntables that include all the best features of both the analog and digital worlds. Once you have put your hands on deck.... you'll never look at turntables the same way again. New Digital Features (* indicates features not found on Technics SL1200): Key Correction (Change the speed without changing the key)* Digital output [S P/DIF] (Plug straight into S/P DIF equipped MAC/PC, MD, or CD Recorder)* Selectable phono or line output (Plug straight into a board with no phono in)* 3.5mm line input (plug portable players into it)* Manual pitch bend [up to 6%]* Blue LED's & indicators Standard Features High torque direct drive motor (2.2 Kgf-cm) Aluminum face-plate Height adjustable Skip-proof straight tone arm!!! Reverse function 3 speeds [33,45,78] Quartz Lock Selectable pitch control [+/-8%, +/-16%, +/-25%] Aluminum platter Height adjustable tone arm Motor off feature Retractable target light Adjustable feet Includes headshell, slipmat, and all cables Settings for Stanton STR8 Series Turntable Specifications for the STR8-100 Description Measurement Motor 8 Pole, 3 Phase, Brushless DC motor Turntable Platter 330mm dia. Aluminum diecast Wow and Flutter Less than 0.20% WRMS (JIS WTD) with 33 1/3 RPM S/N Ratio More than 50dB (DIN-B) Pitch Controls +/-8%, +/-16%, +/-25% Starting Torque More than 2.2 kgf.cm Braking System Electronic Brake Power Supply AC 115V/230V, 50/60Hz Power Consumption 15 Watts Dimensions 17 3/4" W x 5" H x 14 5/8" D 450mm(W) x 352mm(H) x 148mm(D) Weight 9.5 Kg
