just wanted some advice on where to put the terminal on my box. should I just but it on the side or on the back? Also, when wiring the 2 DVC 4ohm subs, should I just run the wire in the path for the vent of my box to get to the other sub or is there another way i should go about it?
thought id post this here. but what kinda terminals do you guys like? i look at the bannana plug ones but idk what they are. i use these ones i got off a prefab box that i really like but the screws are lose and i cant tighten them.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-297 ^^^that is what i always use cause i can rip em off prefab boxes for free. they havent given me any problems at all tho so far. http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-309 ^^^if i ordered em, i would have gotten these.
The one's that i bought for my wife's care and my car as well were the screw type. unscrew it slip the wire in the hole and screw it back on. I've never tried the banana plugs. I'm sure they work well although it would cost you a bit more money considering that you would have to buy the terminal then the banana plugs as well.
