speaker problem
Discussion in 'Car Stereo Speakers' started by bryan7, Apr 5, 2010.
  1. bryan7
    bryan7 New Member
    hi im new here i have a question i just got a set of speakers for my 1999 honda civic lx
    Pioneer Premier TS-D602P 6.5 = front
    Pioneer Premier TS-D902P 6x9 = rear
    so i install the rear speakers with no problem and the 6.5 in the passanger
    side, the wires in the drivers side dint work im %100 sure is not the speaker i tested both speakers on the passenger side and they both work i check the fuses and they are all good what can the problem be?
  2. fstrfvo
    fstrfvo Full Member
    maybe that channel on your headunit is dead r your speaker wire is broken farther down the line
  3. cccullen
    what he said...
    you may just want to try to connect it directly to the heard unit just so you can rule out the dead channel on the HU. if it works then run some new wires to the door.
  4. bryan7
    bryan7 New Member
    is it complicated to run new wires from the headunit i understand that i will need to take out the door panel but would i need to take out the dash
  5. fstrfvo
    fstrfvo Full Member
    No you dont need to take out the dash, just remove the head unit, wire up some speaker wire to the channel that is not working and connect it to a speaker, it does not even need to be installed, just set it on your seat and wire it up and see what happens.
  6. bryan7
    bryan7 New Member
    thanks for the help
