/ Register
speaker noise
Discussion in 'Car Subwoofers' started by STALK, Apr 6, 2006.
  1. STALK
    STALK New Member
    i have a problem with subs.when i turn the gain up on my amp they made a load humming noise when i turn off the radio or change a cd.but when i open the trunk it stops.its still powered by the factory bose radio.any ideas?
  2. The_Ancient
    The_Ancient Full Member
    First off why are you turning the Gain up?
    GAIN IS NOT A VOLUME KNOB!!!!!!!!!!
    Gain is to be set to Match the Line Voltage of the Incoming Signal.
    If you dont know how to do that let me know and I will walk you through it when I get home
    (currently in a Hotel 1700+ miles from home, Flying back Sunday for 1 week for R&R, THANK GOD:lol:)
  3. Jeffc879
    Jeffc879 Full Member
    sounds like you have a wiring problem with your subs. dont use a gain knob. most amps send the signal through the "phone line" and back through regualting the signal at the knob, you loose sq. your ground could be too long or your fuse could be too far from the battery. It sounds weird but it happened to me. there are many causes for that humming.
