I'm looking for a small (half din) eq/line driver. Does anyone know if this soundstream is a line driver also? Any info or suggestions would be great. Trying to stay around 80 or under for a decent piece. Will be hooking up to a 5 channel amp.
the sound stream says a max output voltage of 8v. that tells me its a line driver. the hifonics is too, with 9v out. you can also look into a clarion model.
I just got the soundstream as it was a good deal. I did notice that on the box it says input voltage range 2~6 volts (I did not know this before I bought it). My head unit manual says line-out level 1V. Is this going to make a difference? Will I still be able to use the eq?
yeah sure you can. what head do you have that only puts out 1v? most these day do at least 2v. just curious is all.
It's an older jvc. KS-FX200 or 210. I have both for my two vehicles. I like the 12 disc changer they control.
