sound stops??
Discussion in 'Car Stereo Amplifiers' started by rr188, Mar 25, 2007.
  1. rr188
    rr188 Full Member
    i just bought an apline mrp-m650 amp and hooked it up to a 12inch alpine type r, when i turn the volume up and it starts hitting hard there is no sound from the sub, its like it shuts off only the amp is still on. y is it doing this??
  2. aznboi3644
    how is EVERYTHING wired up???
    Is the protect light on??
    How is the gain and boost set??
  3. rr188
    rr188 Full Member
    the amp looks like its turned on normal when it happens but it doesnt produce any sound the the gain is a little under half,when it happens i can just turn the head unit off and turn it back on and it works again untill i turn the volume back up
    this is how the sub is wired is that 4 ohm because i would like 2ohm (sorry kinda new to this) the amp has 8 gauge power and ground wire with a 60amp fuse (i think) on the power
  4. aznboi3644
    Are you sure your sub is dual 4 ohm or dual 2 ohm???
    take it out and make sure
    From that diagram it is wired to a 2 ohm load
  5. DREAMZmustang
    DREAMZmustang Full Member
    well theres your problem there, ALPINE!!! what junk i say
  6. rr188
    rr188 Full Member
    its a 2 ohm sub
  7. pedro quiroga
    dual 2 ohm?if its wired like the digram you have it wired in to a 1ohm load.
    thats why its cutting off.its going into protect
  8. rr188
    rr188 Full Member
    ya its a dual 2ohm how should i wire it then?... im looking all over and i cant find how to wire a dual 2ohm sub to a mono 2ohm amp
  9. aznboi3644
    There is NO WAY you can wire it to 2 ohms...sorry bud
    You can either use one coil which will lower power handling about 20 percent
    or wire it to 4 ohms by wiring the coils in series
  10. pedro quiroga
    yeah you can only get a 1ohm or 4ohm load from that sub.
    wire a + from one coil to the - of the other coil and hook the other +and- to your amp.that will give you a 4 ohm load.
  11. rr188
    rr188 Full Member
    is it goin to be as loud and have as much power as with a 2 ohm load
  12. pedro quiroga
    the amp will push 400watts into a 4ohm load and 600watts into a 2 ohm load.so you may notice a decrease.
    tell us what happens when you rewire it.
  13. aznboi3644
    difference of 400 watts from 600 watts is not going to be that noticeable...but it WILL be not as loud...just not really noticeably quieter
  14. rr188
    rr188 Full Member
    will the sound quality be any better or will it be worse
  15. aznboi3644
    prolly not an audible difference that you can hear...maybe a trained ear could be able to tell but who cares
  16. rr188
    rr188 Full Member
    ok thats good... i got it wired the other way didnt listen to it to much yet but it doesnt turn off anymore so thats a good thing ill be able to see how it sounds tomarrow thanks for all the help guys i appreciate it i thought i baught a faulty amp fer a while
  17. aznboi3644
    no problem...glad your sh!t runs good now
  18. pedro quiroga
    yeah glad to know those amps can take that kind of beating and not blow up
