$119.00 CD/MP3/WMA/AAC/ATRAC/AM/FM Receiver with Front USB/AUX Input and Detachable Face General Features Color: Dark Titanium / Black Disc Capacity: 1 CD Text Display: CD and MP3 / WMA data displayed Illumination: Switchable: Blue / Green On-Screen Clock: 12H CD: Yes (CD-R/RW) 12V Trigger Output(s): Power antenna Amplifier turn on Antenna Terminal(s): Aerial Input Terminal Audio In: Front Aux input with variable level: -8dB ~ +18dB Front USB input Sony Bus audio/controll terminal Digital Audio Input(s): -Ability to use all forms of USB devices may vary as not all devices are compatible. This unit can be connected to the following iPods. Update your iPod to the latest software before you use it. -iPod Nano 1st generation* -iPod Nano 2nd generation (aluminum) -iPod Nano 3rd generation (video) -iPod 5th generation (video)* -iPod Classic -iPod Touch -iPhone When you connect iPod Nano1st generation or iPod 5th generation, Passenger Control is not available. -This unit is compliant with MSC (Mass Storage Class) and MTP (Media Transfer Protocol) type USB devices compliant with the USB standard. -This unit cannot recognize USB devices via a USB hub. If you have any questions or problems concerning your unit that are not covered in this manual, consult your nearest Sony dealer. Infrared Port: Wireless remote RCA Audio Output(s): Front, Rear, and Subwoofer RCA pre-amp outputs Remote Jack: Optional wired remote terminal USB Port(s): Front USB - Full Speed Max power output: 52 watts x 4 at 4 ohms Speaker Impedance: 4-8 Ohms Band: AM / FM CD Playback: CD, CD-R / CD-RW (MP3/WMAfiles) Digital-to-Analog Converter: 24bit Frequency Response: CD: 10-20,000 Hz Preout Impedance: 220 ohms Preout Voltage: 2 volt Signal-to-Noise Ratio (dB): CD: 120 dB Station Preset(s): 18 FM / 12 AM Tone Control(s): Low +/- 10 dB at 60 Hz Mid +/- 10 dB at 1 kHz High +/- 10dB at 10 kHz Tuner Frequency Range: FM:Tuner Frequency Range(MHz): 87.5-107.9, AM:Tuner Frequency Range(kHz): 530-1710 Tuner Type: SSIR-EXA Volume Control: Tel/Nav Attenuation Circuitry Wow and Flutter: Below measurable limit FM Usable Sensitivity: 8 dBf Frequency Response: FM: 20-15,000 Hz (conventional broadcast) FM: 20-20,000 Kz (HD Radio broadcast) S/N Ratio: 71 dB (mono), 80dB (HD Radio broadcast) Selectivity: 75 dB at 400 kHz Stereo Separation: 50 dB at 1 KHz (Conventional broadcast) 80 dB at 1 KHz (HD Radio broadcast) Current Drain: 3 - 5 amps Input Power: 12 V DC car battery (negative ground (earth)) Input Voltage: 12 V DC car battery (negative ground) Output Power: 52W x4 High Power - 17 watts per channel minimum continuous average power into 4 Ohms, 4 channels driven from 20 Hz to 20 kHz with no more than 5% total harmonic distortion. Power Consumption (in Operation): 45w More...
