I have a 1000W Sony Xplod amp. It's a 2/1 channel amp. One if the channels stopped working. So can I use it as a mono amp with the one channel that works or do I need both channels to be working to use it as a mono? Can someone please help me? I really dont feel like buying a new one right now! :lol:
Um...if one channel is out bridging is out of the question...your only option is to use the other working channel until it gives out...sorry...but soon it will live up to its name and actually xplode in your car (not a fan of sony amps or subs)
get a set of rca splitters and plug it to the one channel that works. and start saveing for a new one.
OK so I won't get the wattage out of the last channel i have? HAHA damn so im just waiting for its end huh?
just send me your amp, i am in the mood too shoot the hell out of something with my SKS!!!!!! :lol: :lol: :lol: Youu can run the amp on one channel no problem, just be sure to do as was stated and run a y adaptir on your RCA input to sum the stereo signal.......it will work, till death do you part!!!
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4852 I guess Power Acoustik and Sony teamed up together to make even crappier products lol
* 12" inch Subwoofer * 2500 Watts Max Output * Mounting Depth: 4.75" * Single Voice Coil * 4 Ohm * HUGE Double Magnet Assembly * 5-Sided Polyethylene Cone * Rubber Surround with "Stroke Stabilizer" * 4-Layer Edge Wound Voice Coil * Impedance : Dual 4 ohm * Gold Plated Binding Posts It has 2500 watts of output, this sub dont efen need an amp, it must be built into the frame and tensile leads..........The gold plating is for maximum resistanse to electrical flow........................the stroke stabilzer is??????????OH!!! so you dont over stroke and hit your hand on the steering wheel, when your checking out the latest hustler magazine
