software
Discussion in 'Subwoofer Box and Custom Fabrication' started by electrolytic, Mar 5, 2007.
  1. electrolytic
    electrolytic Full Member
    does anyone have the link for the subwoofer box design software, i read it somewhere here, can't find it now.
  2. electrolytic
    thanks:cat:
  3. electrolytic
  4. psycho_maniac
    psycho_maniac Full Member
    I would rather use that "sucky" program winisd then pay over 250 dollars. Epically when I'm not working for a company.
  5. aznboi3644
    why do you say that program is sucky???
    you haven't even had much experience with it....I've had it for some time now and it is a wonderful and easy program
  6. psycho_maniac
    I hope you didn't think I said that WinISD was sucky. I dont. I like the program. works very well and has "presets" of subs already built in the program.
  7. electrolytic
    maybe i'm missing something, i downloaded the alpha and beta version, one doesn't list orion and the other is not listing dimensions-measurements. I know there is much better out there. Can you run it through for me azn with an orion h2 15", i will screw around with it some more too. Also how about infinite baffle, is it good for my application if i seal off the back completely and use the trunk as a box, my trunk seals very well, it holds the pressure.
  8. sl0wm03
    sl0wm03 Full Member
    Yea, program is good to me, there might be other programs with more options and stuff. But just from me playing around, I found the "perfect" box for four subs. Says dimensions, volume etc etc.
  9. Ranger SVO
    Then add the Orion specs into WinISD
    Hit [Ctrl] D this will open the driver editor, now you can add in your driver.
  10. electrolytic
    trying..I found this from orion looking for specs and pulled the specific info, maybe i should go with their recommended box, the bottom one for 2500watts. I am still trying the program though too.
  11. electrolytic
    actually now that i look at it the 1500 watt is probably better for how i will run it
  12. psycho_maniac
    Is there any site that has these specs to a lot of subs? That would be really nice.
  13. electrolytic
    ok i got it i think, I can't find any specs for spl, is it the same as efficiency?
    Also is this a good output? i put 85.45 for spl
  14. electrolytic
    I haven't seen any sites that list specs so far..Would be a lot of work lol
  15. electrolytic
    does this look right? sorry for all the questions you probably heard them a million times over. I'm trying to learn as much as i can online before asking lol.
  16. aznboi3644
    seems like you entered the extended bass shelf
    click on help and there is a guide on how to enter new driver data.
    Then do a maximally flat response...open up new graph(you can have multiple graphs to compare) and mess around with box size and tuning and port dimensions to fit your area
  17. sl0wm03
    sl0wm03 Full Member
    Is a driver the same as a subwoofer?
    If it is, i put 4 drivers, and then on that little chart, but at the top of one of my tool bars it says [1]sealed: infinity. Should that say [4]sealed: infinity?
  18. aznboi3644
    a driver is any speaker(tweeter, mid, woofer, subwoofer whatever)
    you can choose between sealed, ported, single reflex bandpass, or dual reflex bandpass alignments.
    Your's says sealed because you chose to model a sealed box
