So this might be pretty cut and dry
Discussion in 'General Car Audio Discussions' started by burnm3w1thf1r3, Jul 10, 2012.
  1. burnm3w1thf1r3
    burnm3w1thf1r3 Full Member
    Last night I was driving home and my amp/subs just cut out and there was a burning smell. I couldn't tell from where. I checked all my connectors and they're all tight and seemingly ok. However my amp is not turning on. I'm assuming the amp is fried but I want to be sure before I buy another one. I am getting power to it (I disconnected the power cable and touched it to a ground to find that it sparked). I do not know how to check the blue signal wire that goes from the head unit to the amp but I assume that is fine because it is new than amp and both ends look perfect fine (no cracks, breaks, or discoloration). How can I test the amp to see if it is fried or is this just a sure thing that its gone?
  2. kostyam69
    kostyam69 Full Member
    i drew you a diagram which should show you how to test if your amp is GONE tester.jpg
