Hello all, This is my first time posting here, so thanks in advance for any help you can give me with what may be an unconventional inquiry. I have a small sailboat and I am trying to install a simple stereo system. All I really want is 4 speakers to play from an ipod. I plan on cutting some holes and installing 4 waterproof speakers, two outside and two in the cabin. I would rather not use a conventional stereo receiver (deck?) for a few reasons. First, I really don't need CD or AM/FM functions. Second, boat battery life is a constant struggle and I want to minimize power drain. And most importantly, I really don't have any place to mount a receiver because they all need at least 6 or 8 inches of depth. There is only about 3 inches worth of space between the layers of fiberglass in the cabin if I were to mount it anywhere convenient. Is there some simple amplifier or receiver device that can just amplify from a auxiliary connection (ipod) to the speakers? I could cut a hole and mount it in the cabin if it were shallow enough, or just bolt it somewhere out of sight and run the aux cable to where I keep the iPod. I would wire it up to the circuit panel on the boat so I could turn it on and off even if it were out of reach. The people I've spoken to so far seem to think I need a real deck of some kind, but I think there should be some simpler fix. Any thoughts? Thanks!
interesting, did several boats years ago, but never a sail boat! Using a small amp (20 wattsx2) run to 4 speakers should give you the sound you want....nothing tear your face off loud, just some nice background music you can hear..... Using a ipod to RCA cable (with approproiate adaptors) Will do the trick, just feed the audio signal to the amp, and use the ipod volume to control the level. A small amp such as this should not tax your battery toooooo much. But be aware that over several hours the battery will be "dead".... This is just a quick suggestion and Not sure if your in a saltwater enviorment or not....that may call for a slightly different technique...
