settings on bx1000d ???
Discussion in 'Car Stereo Amplifiers' started by the dawg, Jun 28, 2006.
  1. the dawg
    the dawg Full Member
    Just got a hifonics bx1000d for my 12" alpine type-r in a sealed box. Any idea what the settings should be at? It has a Subsonic Filter, Lowpass Filter, Bass Boost, Voltage, Phase 0-180.
  2. TheViking
    Turn the subsonic filter ON
    Set the X-over to 80Hz
    Bass boost set at 0dB of gain
    Leave the phasing at 0 degrees
    Input sensitivity set to minimum, turn on radio, play music at about 3/4 up on the volume, trun the gain up till the amp just starts to distort or the subs start to "puke" out..............
    listen to some good familiar music, hows it sound?
    The two controls i would play with are the phase and Lowp[as filter. Phasing will effect your midbass performance, as will the x-over point,basically adjust the thing to where it sounds best. I don't reccomend turning up the bass boost, thats a great way to launch subs or toast an amp, (to this day i dont understand why amp manufactures put those damned bass boost circuits in them! An amp is supposed to ONLY amplify what is fed into it, Nothing more!!!!!!!!!!)
  3. the dawg
    The type-r is in a sealed box so shouldn't I turn the subsonic filter down all the way? I thought that subsonic was mainly for ported boxes?
  4. aznboi3644
    If it sub is in a sealed box than just turn the subsonic filter off...Then do the rest like Vike said.
  5. the dawg
    Hooked up the bx1000d and the bass does not hit that hard. the settings on the amp are : Lowpass about 80; Subsonic at 0; Bass Boost at 0; Phase at 0; Gain(Voltage) little over halfway-about 4 volts. This is in my '97 Grand Cherokee and the sub is in a small sealed box sitting over the right wheelwell firing towards the other wheelwell(side firing). Any ideas on settings or sub placement that would make the bass hit harder and tighter???
  6. weird22person
    weird22person Full Member
    What is the volume of the box? A small change in volume can make a big difference.
  7. the dawg
    The sealed box is about 1.0 cubes.
  8. aznboi3644
    Well just try facing the sub in different positions. I have 2 type r 12's and i have my lowpass around 90-100...sounds great.
    That box should be fine for the sub but the smaller the box the lower the effiency...Try a bigger box if you want.
  9. the dawg
    You say your lowpass is about 90-100 is that halfway on the bx1000d?? The lowpass dial at minimum is 35 hz and maximum is 250 hz.
  10. weird22person
    If you want it tighter go with a slightly smaller box. The manual says .78 is optimum. Acceptable range is .7-1.0. Be careful because larger volume can damage the sub.
  11. aznboi3644
    Nah its on a ****ty profile amp (yes i know it sucks but is temporary).
    But my preference of lowpass is around 90 - 100. Others may say different.
    But it sounds great right now at that setting.
  12. the dawg
    I might try building a ported box as I hear type-r's do better ported vs. sealed. I have never built a ported box , Any ideas where I can find some plans to build such a box??
  13. aznboi3644
    WinISD is a free box building program
    Very helpful.
